Question about Crosley CR49-TW Tweed Traveler Turntable CD Player
My Crosley cr49-ta stopped turning. Can't lift the platter 'cause there's a little nut on there.
4 Suggested Answers
SOURCE: AC adaptor cord
Try a Radio Shack universal replacement power supply like 273-1773 or 273-1776 or 273-1667 with the proper "Adaptaplug" that goes with it. It should do nicely and be sure to observer the proper polarity of the plug so that it will match your unit. Good luck.
Posted on Feb 04, 2007
STYLUSCITY
  • 271 Answers
SOURCE: How do I remove the platter on my record player?
Hi, remove the disc in the centre of the platter. Under there you will find a cir clip that holds the platter in place. It may need a light tap on the spindle with a rubber hammer of piece of wood. styluscity@gmail.com
Posted on Sep 13, 2010
STYLUSCITY
  • 271 Answers
SOURCE: I purchased a Crosley CR49-TA
Hi, refit belt. When changing from 33 -45 speed do it whilst the platter is spinning. Styluscity@gmail.com
Posted on Sep 18, 2010
Crosley turn table is not spinning. Tried replacing belt and moving cue lever to right then left. Think it might be the arm or cue lever. Does anyone have an idea what the problem is or a solution?
Since it is new, you should probably return for refund or exchange.
My guess would be it is the micro switch controlled by the arm.
Make sure the power is turned on and the unit's function selection is set on PHONO and then gently move the tone arm to the right until you hear a "click". Remove any cassettes that might be in the cassette player. Lift the tone arm and carry it over to the beginning of the record.
TroubleShooting
Jan 27, 2016 | Crosley CR49 Portable Traveler 3-Speed...
My Crosley CR49-TA won't revolve. It turns on, and
Most turntables are belt driven. Suggest you take a look inside but remember to unplug the deck first. Usually it's a simple case of slipping the belt back on.
Apr 26, 2013 | Audio Players & Recorders
Power is on, turntable won't turn
Hi, sounds like the belt was not refitted when the motor was replaced.
To replace drive belt on a Crosley turntable.
1. Remove the cir-clip holding the platter in place from the base of the centre spindle.
2. Lift the platter off. You may need to use a flat blade or some similar tool to get under the platter in order to lift it up.
3. NA.
4. Place the belt around the platter pulley making sure it is sitting flat without any twists.
5. Flip platter over the right way up
6. You will see 3 rubber grommets in the platter surface. Remove 1. Through the hole insert a belt hook, crochet hook, kebab skewer, knitting needle type tool and slip it
between the platter pulley and belt in readiness to fit over the motor pulley.
Nov 15, 2011 | Crosley CR249TA Turntable
How do I remove the platter on my record player? When I lift up on the platter something in the middle is stopping it from going any father.
Sep 12, 2010 | Crosley CR249TA Turntable
Turntable will not turn, power goes on. Does this system have a belt for the turntable or is there a manuel or schematics to this system?
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Apr 04, 2010 | Crosley CR49 Shelf System
Turntable wont turn
Lift platter and refit belt. Styluscity@gmail.com
Dec 12, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Belt came off on my crosley cr49 record player
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Aug 29, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Stopped Turning
I had a similar problem, what I ended up doing is taking it apart and jiggling the wires, the motor runs now, but when i opened it up, the belt was losely laying there, how do i put the belt back on? thanks.
Dec 13, 2007 | Crosley CR49 Shelf System
Crosley CR49-TW Tweed Traveler Turntable CD Player Logo
141 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
