TV was turned on for about 1 hr. There seemed to appear a low voltage surg, lights went dim, but only lasted about 2 sec. The TV would not come on. There is a power light in the front middle and it is lit. Manual switch on the side was unable to turn the unit on. Is there a fuse on the inside that could be the problem? I am capable to do some trouble shooting and soldering. I am requesting if it is worth trying to repair the problem or who do I call? I live in London, Ontario, Canada. I used to repair B&W tv many years ago. 519-642-2931
  • hbermanmail Jan 02, 2011
    Fantastic !!! I removed the power, waited a minute, plugged it back in and away it went. Thank you, thank you. Harvey Berman
  • 6,993 Answers
This is an indication that your TV has developed a power problem. Remove its plug from the wall and fix it back into the wall, then turn it on again. If it still does not power on, then the power supply board in the unit is the cause of the problem.
The power supply board might be defective and maybe that's why the unit won't power up. Its receiving power but it cannot transfer the current to the necessary part of the unit because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the unit might not come on.
This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
I do not think the defective power board needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Jan 01, 2011
1 Gal/hr = how oz per sec ?
  1. 1 gal = 4qt 1 qt = 2 pt
  2. 4 qt = 8 pt 1 pt = 2 c
  3. 8 pt = 16 c 1 c = 8 oz
  4. 1 gal = 128 oz
  5. 1 hr = 60 min 1 min = 60 sec
  6. 60 min = 3600 sec
  7. 1 gal/hr =128oz/3600sec or 0.035555556 oz/sec
Aug 11, 2014 | Garden
Hitachi 46w500 went off tonight during storms, low voltage, wont turn back on
There might be a failure on the power supply or horizontal section of the TV even if you see some light inside the TV. Some of the voltages could be missing and that is why the TV fails to power up.
If you know how to use a multimeter, you could check all the fuses from your power supply.
Unplug your TV from the main AC line if you intend to do it yourself.
You will know how much you can do or it might safer to contact a tech.
Let me know if you need further assistance
Jun 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Was fine started great then voltage hand went left abs light came on brake light came on dome lights came on head lights went off all panel lights went crazy blinking then jeep would not start without
Seems to be having problems with the alternator. Alternator itself can be bad, but also the voltage regulator, which sits inside the PCM (powertrain control module).
Don´t continue using with battery voltage around the 10V, because it will ruin your battery as well. Completely charge the battery with an external battery charger and let the alternator be checked out first.
May 16, 2017 | 2002 Jeep Grand Cherokee
The ABS light on tha dash went on and the blower went off and lights dimmed. How bad is this
sounds like your alternator is not charging. abs light could be a low voltage code, blower off- i'm not sure. possibly a power surge which could have blown the blower motor relay. never seen that happen but i suppose it could be possible. are you sure the the battery light is not on? red light that looks like a rectangle? battery light on means bad alternator.
Mar 23, 2010 | 1996 Ford Explorer
1998 Chevy Lumina radio
Unlocking the system from the manual.
1. Turn on ignition. LOC will appear.
2. Press MN and '000' will appear.
3. Press MN again and hold until you see the last 2 digits of your code.
4. Press and hold HR until you see the first 1 or 2 digits of your code.
5. Press AM FM after you make sure the code is correct. SEC should appear, meaning your system is ready and still secure. If LOC appears, the code was wrong. Good luck
Feb 27, 2010 | 1998 Chevrolet Lumina
Only 1/2 voltage to compressor. Also, low voltage
Your control board has failed and you will need assistance. Sea breeze
Nov 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
