Question about Belkin Computers & Internet
All the lights on the N Belkin router are blue ,except the wireless light is flashing yellow. I tried the button on the top which turns off the lights and then turns them back on but the wireless light still flashes yellow.
  • dfalk8709 Jan 02, 2011
    TRIED THE SOLUTION AND STILL HAVE THE SAME PROBLEM
    I HAVE UNPLUGGED THE POWER SWITCH FROM THE ROUTER AND THEN PUT BACK AND RESTARTED COMPUTER AND STILL HAVE ISSUE OF WIRELESS LIGHT FLASHING ORANGE
  • Belkin Master
  • 4,924 Answers
This means that you do not have a wireless connection successfully made...the light will turn blue when you connect a device on it ..If it works OK ..it means it is normal ..as long you do not have a connected wireless device on it ..the light is supposed to do so ..but if it does like that during a wireless connection it means either the wireless is not turned on into the settings or it is not working ..
In this case..you should get into the settings via the browser..using the Ip address...
ex:http://192.168.1.1
or whatever the address it is ..(IP of the router )
in there choose the wireless and re build the settings ..and enable it ..
But ..from what I know it is supposed to do so ...I mean yellow light ...as long as you do not have a successful made connection on the wireless ..
The light turned blue means a working section ...for example if you have a usb attached the usb led will be blue...and so on ..In case a section is turned off..it may act like this ...and this is something you have to check ..
If you never changed the password and admin user name ..they will be like the factory ones...meaning admin for both
Posted on Jan 02, 2011
    President:
  • 3,278 Answers
Hello.
Usually that indicates there is a problem with wireless computer connecting properly to the Router. Disconnect the power from the router and then reconnect again. Restart your computer.
If still a problem, test with another wireless computer to see if there is any difference.
Hope this helps.
Posted on Jan 01, 2011
  • 1 more comment
  • NinaE Jan 02, 2011
    If still a problem, test with another wireless computer to see if there is any difference. The problem could be your computer.
  • Julie Clifford May 19, 2012
    I just pressed the button under my flashing orange lock light (for about 10 seconds) and the lock light turned blue and quit flashing.
    I just pressed the small button under the flashing orange lock light for about 10 seconds and it quit flashing and turned blue.
I have a belkin wireless modem router model F7D1401 v1 and a week ago it would be normal then flash orange and stop working. however now it is a constant orange with the WPS button flashing orange.
I think you have the upper light blinking and lower light solid. Is that right? The upper light blinking means that the connection to your ISP is not working. Try unplugging/replugging the Ethernet cable in the top port (probably yellow and labeled "WAN" or "DSL" or something). Check the other end of that cable. If you have another Ethernet cable, try swapping it out.
If none of that works, call your ISP to check the connection.
Apr 05, 2015 | Belkin Computers & Internet
My router has stopped working this morning. The modem router light flashes blue a couple of times then the security light and modem router light up blue for a couple of seconds the all turn off. None of...
TRY RESETTING THE ROUTER. THERE WILL BE A SMALL HOLE IN THE ROUTER WHERE THE RESET BUTTON IS. INSERT TOOTHPICK OR SOMETHING NON-METALLIC AND DEPRESS FOR 30 SECONDS. THAT SHOULD RESET IT.
GOOD LUCK
Oct 19, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Wireless amber light flashing problem
If the wireles light is flashing Amber .. Some one outside your house is trying to access the Wireless network . If it is always flashing amber.. try with a Firmware update available in belkin.com/au/support.
Thank You
Jul 26, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
The only light on my router is the router light. No other lights are coming on. I have tried rebooting.
When facing the router, Globe/Internet LED is on the right. Below are the LED indicators; Check the steps below:
Wireless Security - This light will only turn on if the wireless security is enabled.
Wireless-Computer Status - This light will turn on if a wireless computer is connected to the router.
Wired-computer Status - This light will turn on if a wired computer is connected to the router. Connect the wired computer to any gray port on the router. (There are 4 gray ports).
Router Status - Power light. Solid blue means the router is on and ready.
Modem Status - If this is off, it means the router is not connected to the modem. Make sure the cable is connected from the modem to the yellow port on the router.
Internet Status - This light will indicate if the router is connected to the internet.
If this is the first time you are installing the router, then what is important is to get the router, wired-computer and modem lights ON. Once they are on, you may insert the CD that came with the Belkin router to setup the internet connection and wireless settings.
Dec 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
Nov 12, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
All light are on (solid blue) except the wireless
The wireless indicator (LED) only lights up blue when a it has a connection to a wireless device.
Once a device (laptop, printer,etc) is configured with the settings that match your router, the blue light will turn on unless there is a physical proble with the router itself.
Is this router new and you're trying to get it setup or was it functioning before and now there is a problem?
Aug 25, 2009 | Belkin (F5D5231-4) Router
Router Security Light is Blinking
I have the same symptoms. In my opinion, this is done because you turned your Belkin from a router to access point position. I did it also (issues with adsl modem/router). By manual the flashing diod means no secure device. But, without pass you can't access your Belkin. So, probably, some fault in firmaware.
Nice day.
Oct 26, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Connection dropping
If the lights are flashing - that's OK. Wireless light will flash because the connections and beacon transmission, port lights will flash because of local connections. We can troubleshoot this for a while but I think this might be a problem with the box. Probably the best option is to replace it. In case you would like to play, try to run Ethereal and capture the packets and analyse them.
Jun 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
64 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
