Question about Dynex DX-LCD37 TV
How to set up caption on my Dynex tv 32'. - Dynex DX-LCD37 TV
    Guru:
  • 679 Answers
Posted on Jan 01, 2011
Cannot get closed captioning turned off on my 46 inch dynex lcd. The setting is off, yet still have closed captioning
Try the basic "re-boot" most digital devices respond to - pull their AC supply plug out for 10 minutes, reconnect, re-setup if asked to and problem may well have been sorted.
Sep 24, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I have a 32" LCD
you need to go to menu/settings options for your tv and there will be an option of cc (closed captioning) turn it off. if thre is a button on your remote. that says cc hit that. if you are connected via a cable box its probably due to the cable box and you need to go to menu/settings and tab thru until you find the closed captioning option
let me know if that helps
Mar 16, 2011 | Televison & Video
I have a DYNEX 42"
Do you have a cable or satellite box connected to the TV? If so the box is probably what is providing the Closed Caption and not the TV.
Robert
Feb 26, 2011 | Dynex DX-LCD37 TV
My closed caption on my new dynex 26L 150A11 will not turn on. I have followed all instructions in the book. I need the cc. any one have an answer? thanks cosycat
There are several possibilities here so you will need to work with me to resolve this problem. In order for Closed Captioning (CC) to work, you need to make sure the CC settings are correct on the TV, and then make sure they CC is switched on. In addition, if you are using a cable or satellite receiver box, CC also needs to be switched on for these "boxes".
It's easiest to start with the TV. Please make sure you have done the following:
1. Check the Closed Caption settings are as follows from the TV on-screen menu as follows:
a) Press the "MENU" button on the DYNEX remote
b) Press the RIGHT arrow twice to highlight the "SETUP" menu
c) Press the DOWN arrow once to open the "SETUP" menu
d) Press the DOWN arrow twice to highlight "CLOSED CAPTION"
e) Press the RIGHT arrow or the "ENTER" button once to open the CLOSED CAPTION MENU
f) Make sure the Closed Caption option "CC MODE" is set to "ON". This can be changed using the UP/DOWN arrow keys to highlight "CC MODE" and using the LEFT/RIGHT arrows to switch between off and on.
The "Basic Selection" and "Advanced Selection" settings are for analogue and digital closed-captions respectively. In addition, the "Options" sub-menu can be used to change the size and style of the digital closed captions (Advanced Selection). All three of these options should eventually be set according to your personal preferences, but for the purposes of making sure it is working, I suggest you set them as follows:
Basic Selection = CC1
Advanced Selection = Service 1
These options are the basic settings which will display only the spoken dialogue of the TV program.
g) Press "EXIT" on the remote to close the menu and return to viewing mode.
2. Press the "CCD" button on your Dynex remote control. This can be found in the bottom right-hand corner of the remote. Each press of the "CCD" button will cycle the closed captions between ON and OFF. (CCD means Closed Caption Display)
3. Check the Closed Captions are displayed and then adjust the Basic and Advanced Selection options until the type and appearance of the closed captions are how you like them.
If you have done the above and still cannot get it to work, please let me know whether you are using a cable or satellite receiver and the brand/model number. I will then be able to assist you further.
Regards,
BElectric
Dec 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
How do you cancel the subtitles on a dynex 32in please
Used ur tv remote control look for the button that said CC.Pushes the CC button made sure all CC1,2,3..all to off.U will not have anymore Close Captioning or Subtitles to u.
Dec 04, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I can't get the closed caption off of my Dynex television...
Check the remote have a button CC.Used the CC button turn off all CC1,2,3 all off.Or goto tv Menu find closed caption 1,2,3 or Text 1,2,3 turn it all off.Will not get anymore closed captioning or big black boxes anymore.
Sep 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I connected dvd player to dynex 32 inch tv. what
You should be connected to the AV input 1 slot. Change the input on the TV to Input 1
Jan 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
We upgraded our cable service and now have HD Digital service with a DVR box. Now the closed caption option will not work on the TV. We have checked all the settings to no avail.
Closed caption is an extra for the TV tuner you have it may not be on the set for HD ie: your set is now recieveing it's picture from the cable box and not your TV tuner probab;y by scart or SVHS cable , and the equipment you have may not have Closed Caption capability check with your network supplier ..... Regards Vortash
PS will it work if you go back to normal tv I think it might .? and if it does case proved ..
Apr 03, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex DX-LCD37 TV Logo
80 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
