Question about Haier hwr10xc6 Air Conditioner
Haier Air Conditioner (24000 BTU, 240 electric)
It vibrates really bad, and no longer blowes out cold air.
    Novelist:
    Champion:
  • 230 Answers
The compressor is probably bad. This is what some do when they are failing. The compressor is the heart of the unit and very costly to have replaced. Only a licensed technician can do this for you. The EPA regulates the refrigerants used to complete this job. In most cases it is cheaper to simply replace the unit then to fix it. If it is new I suggest exchanging it for another one on warranty.
Posted on Jul 08, 2008
Ge 24000 throws beaker not breaker on unit cord
bad breaker or exceeding its amp rating. a 2 ton window units pull alot of amps on start up.
Aug 13, 2014 | GE 24000 Btu Room Air Conditioner EnerStar...
Haier esa410ke manual
my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
Displays "E1" and resetting the
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 08, 2011 | Haier HWR24VC3 24,000 24000 BTU Air...
My air conditioner doesn't produce cold air anymore
It is not enough btu`s most likely,but you can dissasemble the unit and clean it,and the coils.
Jul 05, 2010 | Haier Mechanical Air Conditioner HWF05XC7
Hi, Yesterday I bought haier 12000 BTU air
To determine the cost of using this air conditioner, you will need to find out what your electric company charges per kw/h. This is the standard unit that electricity is charged for. Next determine the wattage of the air conditioner. This should be found on the unit name plate. If you can not find the wattage by the name plate, the take the voltage and multiply by the amperage, this will give you watts. Next multiply the wattage by 24. (watts per hour x 24 hours) Finally divide this number by 1000. This will give you the total Kw that the unit will use in a 24 hour period. If you multiply this number by the cost per Kw that will give you the operating cost of your unit for one day.
ex. electric company charges .25/Kw The unit uses 1000 watts 1000 x 24 = 24000 watts 24000/1000 = 24 Kw 24 Kw x .25/Kw = $6.00 day
Note: all figures shown above were randomly generated in my head, and have no correlation to your calculations. Hope this helps.
May 04, 2010 | Heating & Cooling
Air Conditioner will not cool. Only fan lights up
My AC seems to be running but it is not blowing cold air out. What maybe the problem?
Jul 16, 2009 | Dometic Rooftop RV Air Conditioner
I bought a haier electronic control air conditioner model HWR10XC6 on 6/30/08. I installed it. When I try to use the cool mode the air conditioner will only blow out cold air for about 5 - 10 minutes and...
It sounds as if the compressor (that provides the cooling) is cutting out due to either a faulty thermostat or is itself overheating.
Obviously check the thermostat is able to move between it's minimum and maximum levels, anthat this corresponds to the compressor cutting in and out.
With maximum cooling selected, the compressor should not cut out untill the thermostat says it's cool enough. If it does, there is a fault, and you have every right to a refund or a free repair/ replacement.
The fault is usually centered around the compressor electrical components if it is not under any warranty, but it should be. Even if the store does not want to know, the manufacturer should back it for 1 year.
Thanks for using Fixya!
If you need to attempt repair - ask again.
Jul 06, 2008 | Haier Heating & Cooling
9000btu Haier portable air conditioner HPAC99ER doesnt blow cold air. What do I need to do?
I own the Haier 9,000-BTU Portable Air Conditioner - White. This is the second day that my unit has blow out air that smells really bad. I went to check my unit to find that there was a leak of some sort of chemical that smells like what is blowing from my unit. What should I do?
Jun 06, 2008 | Haier Heating & Cooling
Haier hwr10xc6 Air Conditioner Logo
52 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
