Question about Music
Y does my rp90`s expression pedal not work it worked when i first plugged it in but now it doesn`t
  • Music Master
  • 5,603 Answers
Some of the settings the pedal does not affect the sound. Try different settings... Also make sure you have the correct power adapter.
Posted on Jan 02, 2011
How to connect an expression pedal to a Boss gt-3
Just plug FS-5U or FS-5L or EV5 / FV300L (Roland),or other external switch to SUB EXP PEDAL.
You can also use pedal switch that you create by yourself.
Use stereo phone jack and cable.
It can be function for 1 or 2 switch.
Setting function for SUB-EXP-PEDAL is at UTILITY-GLOBAL menu.
You can set switch 1 or 2 for what do you want to function each switch at the external pedal.
If you want to connecting external expression pedal (FV300L),just plug it to SUB-EXP-PEDAL. Setting is same as above.
Aug 31, 2015 | Boss Music
Hi. I have bought a Behringer Bass Synth BSY600 and a Boss FV-300L Volume / Expression pedal. Both work on their own but i can't get the Expression pedal to work with the Bass synth. The expression...
The FV300l WILL NOT work tying it into the EXP of the BSY600. What you need to do is to run your guitar into the IN of the BSY600 and use TWO audio cables from the BSY600 output, the OUT and the DIR out and run those into the two IN's of the FV-300L. Then use whichever function by connecting the two OUT''s of the FV-300L to two channels of the mixer or a two channel amp so you could proportion the BSY600's effects as desired. You could also just use whichever out from the FV-300L you want which originates in the BSY600. The BSY600 is made to use an expression pedal that is a single TRS plug which is simpler, but you can use your FV-300L as I have described just as well, it just can't use the EXP input of the BSY600.
Jun 22, 2011 | Behringer BSY600 Bass Synthesizer Ultimate...
My rp90 reads out pd when i plug it in and is stuck in this pd mode and doesnt let me play anything how do i unstuck it from this pd mode
Try a factory reset. This is the procedure
1. Press and hold the Store button while powering up the RP90.
2. When the display prompts you with FR, release the Store button.
3. Press and hold the Store button for 3 seconds until RS appears in the display and release. The Factory Reset procedure takes approximately 10 seconds.
4. Once the factory reset has finished you will need to calibrate the Expression Pedal.
May 14, 2011 | Music
Hi I have a Behringer Fcb1010 and I want to programme one of the expression pedals as a volume pedal but am unsure how to do this?
I have Behringer Fcb 10 10,but i want to know how expression pedal volume work when connect with GR55.
Feb 11, 2011 | Behringer Fcb1010 Midi Foot...
What should I do for connect the fc7 to Roland RD-700sx for controll the loudness? Thanks a lot Heinz
Yamaha pedals MAY not work on the Roland... However, read page 85 of your manual regarding the FC1 and FC2 jacks. plug the pedal into one of them and then assign/select that jack as controller #7 (CC7) which is the volume controller number used in MIDI.
Jan 23, 2011 | Yamaha FC7 Pedal EXpression
The foot pedal (not the switches) on my "DigiTech RP90 Modeling Guitar Processor does not work...it will move but it changes nothing.
All DigiTech expression pedals use an optical system instead of potentiometers.
Either the light is broke, or the filter.
The filter protrudes from the bottom of the pedal, and is darker at the top and gradually fades to clear at the bottom. If this breaks off, then there's nothing to limit the amount of light to the optical system.
If it is the light, then you'll have to have it serviced by someone qualified to work on it. Your local music shop should be able to help you out.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Jan 13, 2011 | Music
I need to know how to restore factory settings on digitech RP RP-90
Here is the link to your manual if you don't have one:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP90/RP90Manual18_0490_A.pdf Page 34 tells you how and don't forget to calibrate the expression pedal. Page 35 tells you how. Hope this helped.
Nov 09, 2010 | Music
Expression pedal wont work
Here is a link with a source for the manual on the right of the page:http://www.digitech.com/products/Bass/bp200.php Further information can be found at support at the top of the page.
Mar 20, 2010 | Music
My DigiTech RP90 expression pedal isn't working at all
If you are getting no display after you try powering up properly check the plug end of the power supply with the supply plugged in with a volt/ohm meter. You should get a reading of 9volts. If you don't ,your power supply is not working. Sometimes the wire breaks where it goes into the supply and sometimes where it goes into the plug. Your power supply jack may be broken where it is soldered to the circuit board. If the unit has power you can do a factory reset. The procedure is on page 34 and 35 of the owners manual that you can download for free here:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP90/RP90Manual18_0490_A.pdf Let me know if this helps.
Nov 26, 2009 | Music
Digitech RP90 Expression Pedal
Same thing happened to me but i didn't drop the pedal.Try to recalibrate the pedal cause mine worked after that.Look in the Owner's Manual at the recalibration section.Hope this will work for you.Good luck with it!
Mar 29, 2009 | Music
Music Logo
121 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
