Question about Pentair Whisperflo 1 12 Hp Pool Pump Wf26 011773 ()
I have a Pentair 1 1/2 HP pump. With power on the motor will just hum but not start. When I take the end cap off and manually turn the motor shaft and then apply power the pump will start and run normally. What do you think?? It will run each time I apply power but if the pump stays off for a minute it will not start unless the shaft is turned manually.
    President:
  • Pentair Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It is the capacitor or the starting switch but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak. Start with the capacitor.
use a digital multi-meter (DMM), preferably with a capacitor setting, or an analog meter set for Ohms. With an analog, you should see the needle deflect as if testing a closed circuit then it will slowly drop to 0 if the capacitor is good. If it doesn't move or moves and stays to the side showing a closed circuit the capacitor is bad. If you notice a burn hole near the terminals on the end of the capacitor do not bother to test it. If you do not have access to a meter you can try grounding the posts together with a screwdriver to see if they arc although it is not a very reliable test method. Be sure you are holding on to an insulated handle for the tool you use to short the terminals together or you can get a good poke.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
If this answer does not fix your problem, please comment with additional details or contact me thru our site at www.arrowpools.net prior to rating the answer; I'll do what I can to help. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 01, 2011
What could be wrong,My pump wont turn on , it makes noise but wont kick on
open it up and see if the impeller will turn freely when it is disconnected from power. Call pool guy or pool store and see if it just needs a solenoid.
Sep 19, 2014 | Hayward 1.5 Hp Northstar High Performance...
Hayward Pump motor, hums but won't start. If I turn the shaft it will keep running but once I turn if off it will not run until I do the same thing again. I have replaced the capacitor but still the s
1 or 2 capacitors on this motor?
Sometimes there are two...
One is a "Start" capacitor and if a 2nd one, that one is a "Run" capacitor.
If only 1 capacitor and you have replaced it... if not a faulty capacitor, then your windings are shot?
When I test a motor with this symptom, I will use the "Clock Face" method of checking for "Dead Spots" on the winding/stator:
Once you have removed the shaft cap on the back of the motor, I presume you have done this since that is only way to turn the shaft manually to get it to run in the manner you described. Place a small mark (1/4" long?) on the outside perimeter of the shaft, say at the 12:00 position. See picture attached...
Then flip switch, does it start or hum?
Then rotate shaft until your mark is now at the 1:00 position. Flip power switch, running or humming?
Do this at all clock positions as you turn/rotate shaft until you reach 12:00 once more. If the pump hums at all clock positions completely dead motor or bad capacitor. If a dead spot is at only one clock position, then absolutely, bad motor - either rebuild or replace.
Coincidentally the motor may stop each time on a dead spot, where the motor won't start due to a fried portion of the stator/winding/armature, only a major repair fixes this. The purpose of the test is to place the position of the stator in a different position in relation to the windings. If humming all the way around, then possibly a bad capacitor, because it is not starting in any position. If it starts say at all positions except 4:00 and 9:00 then motor is bad.
Good luck
Aug 30, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
How to separate pump from motor
take screws off around housing that separates motor from wet end remove diffuser then remove screw from impeller backwards thread and hold back shaft of motor after removing still hold shaft and turn impeller off regular threads make sure to replace seals
Apr 16, 2013 | Pentair 1 hp WhisperFlo InGround Pool Pump...
I had a hayward 11/2 hp 2 sp...I put a AO 2 hp 1 sp on my ing. pool and how it just hums and shuts off. I checked everything out and primed it before I tried to start the pump. Can anyone help
Turn off the power and remove the end cap at the center back end of the motor. The end of the motor shaft is then exposed and you can use a 9/16" open end wrench to verify that the motor shaft is turning freely.
If it offers resistance the pump needs to be opened and checked to find out why. If it does move freely, take it to a pool store or motor shop to test it. Rarely, a motor gets out of the factory DOA.
Jan 19, 2013 | Pool & Spa
I have a brand new 1 1/2 hp superflo. I wired it in and turned on the power, it hummed for a few secounds and trip the breaker. now it it wont work and just immediatly trips the breaker. Any ideas as
It sounds like the motor shaft is stuck. The back end of the motor has an end cap that comes off so you can access the end of the motor shaft. Try this with the power off; Remove the cap (center rear of the motor),Using an open ended 9/16 wrench you should be able to turn the shaft back and forth. A motor that has sat for a while will sometimes act like yours did. A nudge with the wrench usually breaks it free. Remove your wrench and turn pump on. If it still won't start the motor may be defective.
Dec 28, 2012 | Pentair Superflo 1 1/2 Hp In Ground Pool...
Pentair Whisperflo 1.5 hp motor will only turn with help. Can it be fixed?
maybe bad start up capacitor remove match and replace or replace pump motor or pump
Sep 02, 2012 | Pentair Pool & Spa
Pump does not turn on it just hums
bad start up capacitor turn off and try spinning shaft then turn back on if doesn't work replace motor or pump
Apr 03, 2012 | Pentair 1 hp Dynamo Pump
No suction and pump turns on but makes a humming sound. it is only 4.5 years old.
ok the humming sound can be one of two things. The worse case scenario is the motor is frozen and therefore dead. On the flipside tho sometimes it can be as simple as something binding on the impeller so that it cant get its initial spin and thats why it makes the humming sound and would eventually throw (trip) the breaker. The way to test is to first *****************MAKE SURE THE POWER TO THE MOTOR IS OFF***************** AND THAN DEAD CENTER ON THE BACK OF THE MOTOR (basically oposite the basket ya know where the noise is) THERE WILL BE EITHER A CAP THAT LOOKS LIKE A NUT AND WITH A QUARTER TURN IT WILL COME OFF OR THERE WILL BE A INDENTED OR INVERTED CAP WHICH YOU WILL NEED A THIN FLATHEAD FOR AND YOU TAP IN A COUPLE SPOTS TO PRY IT OUT. EITHER WAY WHEN YOU GET THAT OFF YOU WILL SEE THE END OF THE SHAFT. ( Its made out of stainless and its flat on two sides so that a 1/2 inch wrench can fit on it). IF YOU THAN TURN THAT SHAFT AND IT SPINS FREELY YOU PROBALY HAVE A DEAD MOTOR. IF YOU SPIN IT AND IT FEELS A LITTLE GRINDYTHAN MAYBE SOMETHING IS STUCK IN THE IMPELLER. IF THATS THE CASE GO AHEAD AND MAKE A FEW ROTATIONS AND THAN TRY TURNING ON THE PUMP AGAIN TO SEE IF THAT HELPED TO GET IT TURN OVER. MAKE SURE NOTHING IS ATTACHED WHEN YOU TURN IT BACK ON.
Pentairs warranty is one year if you just bought a pump by itself and three years if you have three or more major pieces of Pentair or Sta-Rite equipment installed at the same time. Also the warranty is for the original owner only it is non-transferrable.
Some of the common causes for this condition is if the basket in the pump ever cracks than stuff can get pass and clogg or bind the impeller. Now dead center on the shaft and the motor is whats called the Ps-1000 mechanical seal and if that develops a leak that isnt noticed or caught for a while than eventually the water from the leak will make it back into the bearings and windings of the motor and cause it to die.
Dec 29, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
How to seperate pump from motor
Disconnect all power. Remove the six bolts holding the seal plate to the wet end. Remove the two small allen screws to remove the diffuser. Remove the dust cap from the end of the motor and secure the shaft from moving. If installed, remove the Phillips head screw in the center of the impeller by turning clockwise (left hand threads). You can now remove the impeller by turning counter clockwise, note that you may need an impeller wrench to remove it and a specific tool to hold the shaft while you remove the impeller. Once the impeller is off you can remove the four bolts that hold the motor to the seal plate. This process just needs to be reversed to re-install but you will need a new shaft seal (PS-1000).
Jun 30, 2010 | Pentair 1 hp WhisperFlo InGround Pool Pump...
Dynamo pump is locked--just hums
Try turning the motor from the back. Remove the end cover and turn the shaft. If it still hums the motor will need to be replaced.
Apr 27, 2009 | Pentair Dynamo 3/4 Hp Above - Ground Pool...
Pentair Whisperflo 1 12 Hp Pool Pump Wf26 011773 () Logo
171 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
