Question about Whirlpool Duet GHW9150P Front Load Washer
What is an f20 error message - Whirlpool Duet GHW9150P Front Load Washer
    Scholar:
  • 85 Answers
This has to do with insufiicient water supply. By switching water temperatures you can troubleshoot. If the machine works in one temperature but not another that can show you which inlet hose has a problem. A kink, low pressure, air in the line, or sediment in the screen on the end of the hose can cause this problem. A bad water valve can also cause a problem with one water temp but not another.
These machines are also prone to pressure switch problems.
After a time the small hose that comes from the pump area to the pressure switch located at the top of the machine can clog. To check this perform the following:
unplug machine
remove back or top of washer
locate pressure switch (round, about 4" diameter with wires and a black rubber hose)
pull black tube and blow air through it until clear
reassemble, plug in and test
If this does not work, then you could either need a new preesure switch or a flow meter.
Posted on Jan 01, 2011
ERROR FF20 AND FF5
Hello Heather, this is JK. I understand that you received two error messages, F20 and F5. Typically, the F20 error indicates a communication failure between EOC and ESEC system and the F5 indicates that there is a runaway temperature. Based on the fact that you received both error messages, you may need to replace the EOC (Electronic Oven Control). Hope this helps!
Apr 19, 2014 | Frigidaire Kitchen Ranges
I am recieving a F20 error message on a brand new whirlpool washers each time i use it. Its a Duet Steam.
F20 means water is not entering the machine at a sufficent rate, check water supply is connected correctly, turned on and hoses are not blocked or kinked or pinched.
Jan 14, 2011 | Whirlpool Washing Machines
Recently I have been getting an F20 error message. What does this mean?
F20 No water detected entering machine
Could be a couple things . Clogged inlet screens on the water valve, flow meter gone bad. Pressure tube has sediment in it.
Aug 31, 2010 | Kenmore Elite HE5t Washer
I am getting an F20 error message or SUD. I have
http://www.wikihow.com/Fix-a-Whirlpool-Duet-Washer-F-20-Problem
Jan 22, 2010 | Whirlpool GHW9300 Duet Washer
Finepix f20 to windows vista
Use a card reader to download your pictures to a folder you create on your desktop.
Oct 05, 2009 | Fuji FinePix F20 Digital Camera
My Fujifilm FinePix F20 digital camera gives me a zoom error message and the lens does not open when I power up
problem on lense .remove ur lens on ur camera and cheak the motorgears which are supporting to move lense
Jul 11, 2009 | Fuji FinePix F20 Digital Camera
F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error message on Navman Navman F Series Failure Unable to detect internal memory. Please return the unit to dealer. Can anyone help?
I have a F20 here I am currently tring to fix.
The error comes from the internal memory card being faulty.
It is only a micro SD car.
It may be totally usesless, or need re-programming via the USB port.
You can download the firmware, and it fixes a working MicroSD card.
If your card is damaged, then you will have to replace it, and strip the F20 down to do so.
Then you can upload the firmware.
I warn you, though.
Stripping it down is a bit tricky.
I replaced this F20 memory card, and put on the firmware, but have a new error, that it cant find any maps installed.
Hope this helped you
Michael
Scratchmittens@htomail.com
Jul 14, 2008 | Navman F20 GPS Receiver
Zoom Error
i have a duji f20 le zoom lens partly out when turn on says zoom error can you solve this please
Feb 22, 2008 | Fuji FinePix F20 Digital Camera
Whirlpool Duet GHW9150P Front Load Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
