Question about Toshiba Televison & Video
Ref. Toshiba VCR, model RDXV59DTKB2 I copy ,using the dubbing function, of VHS to DVD. The disc then works in this and most other VCR's but will not playback in my PC nor my portable DVD player. WHY? I have used the following software to solve this problem without success, Windows Media Player, Wndows Media Center, AVS4You, Roxio, NTI Please help as I have lots of VHS tapes to convert to DVD discs. Joe Shepherd, Northants.
  • Toshiba Master
  • 5,444 Answers
Check if your DVD drive in your computor is the same type as your recorder. IE A DVD + or DVD -.
Some types of drive will not play the others. You might need to upgade your drive in your computer to one that will play nearly all formats.
Posted on Jan 03, 2011
I have a Toshiba RDXV59DTKB2 Hdd & DVD/Video
The control board is shot including the on/off switch.
Jan 21, 2013 | Televison & Video
On the Panasonic DMR-E75V DVD Player / VCR Combo; I lost my manual; how do you dub (copy) the vhs to dvd?
You can enter the menu option on-screen - [FUNCTIONS] button, then, look for 'COPY' then select VHS as source DVD as destination.
Or you can download a .pdf copy of the manual ONLINE - it's free for this model.
http://service.us.panasonic.com/OPERMANPDF/DMRE75V.PDF - you can save this manual for future use.
Feb 23, 2011 | Panasonic DMR-E75V DVD Player/VCR
I need to copya vhs to a dvd. Can you give the steps one by one please?
Can you provide the model of DVD/VCR player? Not all models do this.
For the ones that can, you need to use the Dub feature. Put a blank DVD (or one with sufficient space) in the DVD tray; initialize the disc if you are using a rewritable disc (RW). Then put the VHS tape into the VCR (you may want to break off the write protection tab). Then set the unit to VCR mode and forwared the tape to the desired recording point (copy-protected tapes can't be copied). Then some models have a dub or copy button on the unit and/or on the remote (press it and follow the onscreen prompts to select VCR to DVD, recording quality and press Enter to start). The copying will stop when you press Stop or run out of space on the DVD. On some models, you need to do this with the on-screen menus. For those, the look for a Dub feature (where it is will vary in the menus - usually in the same submenu as timed recording) and then select VCR to DVD and the rest.
I hope this helps.
(I'll be glad to provide more information if you provide a specific model. I've worked with several brands and there are some differences in the setup routine. My current unit is a Zenith with a Copy button on both the front panel and the remote.)
Dec 28, 2010 | Philips Magnavox DVD/VCR Dual Player
Hi. I have Toshiba sdv395 & was told I could dub VHS to DVD. There is no info in the manual. Can it be done & how. Roy
This is a DVD player. It will not write to DVD but will play discs you have recorded elsewhere. You could (with non-copy protected discs) dub the DVD to VHS. To go the other way, you would need to connect the player to a computer with appropriate software or other DVD recording device.
I hope this helps.
Mar 14, 2010 | Toshiba SDV395 DVD Player/VCR
Dubbing vhs to dvd
I have a toshiba dvd/vcr vr610 And I don't know how to dubb.I don't have the manual
Dec 30, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Copy from vhs to dvd- want to speed process ???
I'm afraid, VHS tape have to be playback on standard speed for good picture and sound and dvd would also burn accordingly.
Noo way for fast dubbing because VHS tape video is analog signal that changed into digital signal in circuits to write on dvd disc.
I hope you understand how this dubbing works.
Nov 08, 2009 | Emerson EWR20V4 DVD Recorder/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Open Questions:
I was given a 2007 Toshiba Regza LED television ( I believe it to be LED just because of the Year 2007.) I have the television plugged into the wall standing alone with nothing connected to it no wires no cable boxes nothing. When I push the power button on the side it goes on because the green light is on the bottom it's not flashing but it is on okay. Now what's happening is I'm not getting any picture and I went on to shop Jimmy's and they recommended that I contact you. The back lights are on as I can see through the slots on the back of the television that there is light coming from there. The thing I'm trying to find out if I did the flashlight cuz I couldn't see any picture whatsoever and I don't know I turn the volume up as much as I possibly could through the side and also with the remote. I change the batteries in the remote of course to see make sure that they were working and I shine a flashlight on the screen I could see no picture whatsoever no menu picture no nothing and no sound. So my question is to you, after following shop Jimmy's recommendations it said that if you have your back lights working but you still have no sound or picture then you would need to replace one of two parts or both. I'm not sure what those parts are called I forget but my main question is how much is it to even get those parts and can I still get them. Like is it really worth doing that or should I just go and buy another television. Mind you to see me was given to me at no cost so that is basically the question would it be worth buying those two parts that they recommended and putting them in one at a time or should I just go get a whole new television remember I'm not which call Rich either so... If you could contact me with an answer that would be great please be specific as I am not what you call text Abby okay? I thank you in advance for your time patience and cooperation and helping me to answer this questions. I look forward to hearing from you! Respectfully, Stephanie Whitman PS can this television only be controlled by the remote. There are buttons on the side but to truly get the best quality of the television I would need to use the remote correct?
Jun 14, 2018 | Toshiba Televison & Video
Televison & Video Logo
408 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
