Question about Microwave Ovens
Part of a jar of peanut butter right next to or touching the door's hinged corner got hot. Paper on top of the microwave got warm. Is this dangerous?
    Brigadier General:
  • 8,909 Answers
Probably not but who likes warm peanut butter? It is gross enough when cold!
Have a good New Year.
Posted on Jan 01, 2011
My frigidaire microwave door is sagging and is about to fall off
You will need new door and hinge replaced
send model # for price quote
May 13, 2015 | Frigidaire PLMV169DC Microwave Oven
Grandson came up under it and caused the hinges to not hold the door shut
If the door doesn't work right it is time to buy another microwave. Microwave leaks can be dangerous.
Oct 20, 2013 | Samsung SMH7159 Microwave Oven
I need to change the door on my Kenmore microwave oven
1.Unplug the microwave and set it on a table or workbench. If you have a built-in microwave, you may have to remove some mounting screws or retention clips to get the microwave out of the support bracket. Open the door and take out the glass tray.
2.Pry off a corner of the plastic panel on the inside of the door with a screwdriver or butter knife. Once it is loose, work the screwdriver or knife all the way around the glass and remove the panel.
3.Ask someone to hold the microwave door as you disconnect it from the hinges. Depending on the design of your microwave door, you may have to remove a set of screws or slide a pin out of the hinge to release the door. Remove and discard the old door.
4.Have your assistant hold the replacement door up to the hinges. Attach the door to the hinges by reversing the previous step. Snap the plastic inner panel into place around the glass. Move the microwave back to its original location. Insert and tighten the necessary mounting screws if you are working on a built-in microwave. Set the glass tray back inside the microwave and close the door.
Sep 21, 2011 | Microwave Ovens
The top right corner of my panasonic nn-h275 otr microwave door leaves a approx. 3cm gap when closed. Fixable? Dangerous?
If the door is warped cheaper to replace the whole oven, the 3cm gap is a hazard because you have dangerous radiation leakage, the levels are exceeding safety standards and should be removed from service immediately.
Mar 27, 2011 | Panasonic NN-H275 Microwave Oven
GE Spacemaker microwave model JVM130J - handle loose
Yes, you're right about the screws. The inner door is held by clips. Just pop it out using a butter knife or something similar. You might need to remove the door from hinges first (It's been too long after I repaired one of these, so I don't remember exactly).
Oct 14, 2009 | Microwave Ovens
Frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Mar 10, 2009 | Frigidaire GLMV169D Microwave Oven
Microwave Keypad Is Hot
check blower fan, and maintained gap between oven and wall at last 2 feets. some heat comes to pad very heat may be some prolem. check every thing and reply me.
Aug 21, 2007 | Emerson MW8108P Microwave Oven
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
Chances are the door panels separate as shown in the photo I have attached below. Panel replacement can usually be done without removing the door from the microwave. In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges. I generally do not advise removing the hinges from the microwave. Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in. Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption of nearby electronic devices. You can find exploded view diagrams and order parts here: http://tinyurl.com/gv383 We have critical safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 06, 2007 | KitchenAid KHMS147 Microwave Oven
Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
May 14, 2006 | KitchenAid KEMC377K Convection / Microwave...
Microwave Ovens Logo
73 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
