Question about Nespresso Essenza C100 Espresso Machine/Coffee Maker
Hi there, I need help with my nespresso machine. After storing it in a lower cabinet for a few months, the machine became a roach motel. I have cleaned all that I possibly can and have been running water through it constantly but it needs to be dissected and cleaned from the inside (I can still smell the roach poop!) can anyone help?
My nespresso c190 makes coffee watery
Have you decalcified the machine? They need descaling about once every year - 18 months, and one MUST use the Nespresso Descaling Pack, which is designed for all Nespresso machines. I can't understand why the capsule holder is tight, unless you have used so-called "Nespresso Compatible" capsules, which can cause this. The machines are designed for use only with genuine Nespresso capsules.
Feb 28, 2015 | Nespresso C190 Espresso Machine
Nespresso U coffee does not come through the spout
There are two nozzles in front of the machine attached together, the nose of the bigger one on the top slides into the smaller one on the bottom. When it makes coffee, the spout outside the machine becomes lower so coffee can come out. When it is done making coffee, the spout goes up so water/coffee drips in the drip tray. If one of the nozzles breaks, the spout on the smaller one will not go down and the inside end is lower and coffee goes inside the drip tray. It has nothing to do with cleaning.
Jan 20, 2014 | Nespresso Coffee Makers & Espresso...
Oven
Unfortunately it's not easy to remove. Try a roach motel in front of the unit.
May 30, 2013 | Ovens
Our machine does not puncture the Nespresso capsule - so we only get murky water.
I just had the same problem with my new (less than one month use) Nespresso U. (the top of the capsule doesnt puncture and only water comes through). I called Nespresso customer service and a very helpful man suggested I run water through three times by pushing the top slider open with the Longa button pushed and then closed without a capsule in the chamber. That released the air bubble and now I am enjoying a wonderful cappuccino again! The customer service is fabulous, there was never a suggestion of charging me and I was told that Nespresso will send me a free loaner machine if anything goes wrong in the future that can be readily fixed over the phone. The Nespresso U is the best thing I ever bought.
Aug 25, 2010 | Nespresso C100B Essenza Single-Serve...
Maytag performa LAT3500aaae is it hard to replace
please check any locking system is provided in the cabinet and replace is it. if problem exist check for the screws of the machine must be properly screwed up
Dec 23, 2009 | Washing Machines
Coffee tastes very acidic
Hi kdimof,
I realize you posted this problem over a year ago, but I was curious to see if you were ever able to resolve this problem, or find the exact cause.
I have the same issue you describe. I descaled my Lattissima for the first time using the Nespresso descaling solution. And now, two months later, I cannot remove the chemical smell/taste of the descaling solution. I've run numerous descaling cycles with just water (as per Nespresso's customer service advice), with no success. I was forced to accept a refurbished machine (even though my Lattissima was only 3 months old). The refurbished machine is currently on the way. We'll see if I have the same issue when I descale this one.
Thanks, Redfran
May 14, 2009 | Nespresso Lattissima 660.R
Water leakage inside
Use less water....
Apr 29, 2009 | Krups Nespresso 554
Water leaks from the top of the C190 Espresso Machine
in our case the problem was fixed easily: the metal piece in which the capsule sits is screwed in on the top. When it became loose our machine started to leak water from the top. So the problem was solved by retightening it!
Oct 28, 2007 | Nespresso C190 Espresso Machine
Nespresso Essenza C100 Espresso Machine/Coffee Maker Logo
528 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
