Question about Thermador MBES Microwave Oven
The glass plate inside will not rotate - Thermador MBES Microwave Oven
    Brigadier General:
  • 8,909 Answers
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Posted on Jan 01, 2011
What size glass tray do I need for my Westinghouse model WCM770B/W microwave? I broke mine and cannot find the answer in the manual.
Frequent thrift stores or yard sales, or take a tape measure to the inside of the microwave
. If your dish was square, the glass plate should likely be about 1 inch less wide and 1 inch less deep that the inside of the box.
If you have a round plastic rotator, the dish should be about 1 -2 inches bigger in diameter than the plastic rotator.
God bless your efforts.
Oct 23, 2017 | Westinghouse Microwave Ovens
Where can I get a glass turntable
Are you talking about just a new glass plate for your specific oven or a generic turntable mechanism? If just a glass plate, you have provided no brand or model info. Just examine how your old plate engaged - they aren't all the same but some will interchange. There are also inexpensive turntable devices that can be used to retrofit ovens without a rotating mechanism.
Sep 09, 2014 | Microwave Ovens
Center will not rotate
The glass plate is driven by a motor underneath. Power may not be getting to the motor or the motor may have failed
Jan 17, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The revolving glass plate on Panasonic NN-GD546 no longer revolve
the plate is controlled by a rotating motor.the motor is probably stuck or bad.
Feb 24, 2010 | Microwave Ovens
The glass plate will not rotate when trying to heat up your food...
Sounds like either the turntable motor has seized or that the shaft of the turntable motor has broken off inside the roller ring. You may need to chek with your local De'Longhi repairer.
Nov 29, 2009 | DeLonghi Microwave Ovens
One of the legs supporting the glass plate is broken so the plate can't rotate inside the oven chamber
You can order parts for this brand from Encompass . Or you can call them toll-free at 866-779-5835.
Oct 06, 2009 | Sharp R-1480 Microwave Oven
Glass plate does not rotate
on the bottom of the micro underneath the shield there is a small moter for turning the plate.. also if the plate and roller are not centerd correctly it will not turn ,.. remove the plate and balence a glass on the triangle in the center of the micro shut door and start micro observe if turning ..also some micros have a button selection on the control to reverse the micro plate rotation and stop it --check these things and get back to me..
Aug 10, 2009 | Microwave Ovens
Thermador MBES Microwave Oven Logo
163 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Chuck
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
