Question about Toshiba REGZA 42RV530U 42 in. LCD HDTV
Base stand screws are missing for Toshiba Regza 42XV540U. Where to find them?
SOURCE: taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
Posted on May 17, 2009
vinnyq
  • 157 Answers
SOURCE: I have a 52in Toshiba flat screen that I want to
Check carefully with a flashlight to see if you removed all the screws completely. The stand should pull out quite easily as long as all the screw are out on the back bottom center of the TV.
Posted on Nov 09, 2009
  • 73 Answers
SOURCE: im wanting mount my 37 in toshiba regza but i can
Carefull turn the tv on it's back and remove the 2 black screws in the bottom of the stand in addition to the screws on the back that I assume you already removed.
Posted on Nov 10, 2009
dave1645
  • 834 Answers
SOURCE: Removal of Pedestal for Toshiba Regza 32HL67U
more than likely it is a Philips and there should be four marked with arrows
Posted on Nov 30, 2009
SOURCE: how do remove the base on a toshiba 42XV540U?
toshiba 42xv54ou it wount trun on and it blink a yellow light three times
Posted on Dec 25, 2009
How do i remove swivel base from toshiba regza 42xv540u
Make sure you check the owner's manual. You can probably get a free download if you lost yours.
Some TVs have screws on the backside near the bottom, not just underneath.
Jun 17, 2014 | Toshiba REGZA 42XV540U 42-Inch 1080p 120Hz...
I cant remove the stand of my toshiba television model number 32AV554D
Take a good look as it should have 4-6 machine bolts holding it--be careful as usually it must be laid face down to remove----no weight on the screen or downward pressure or bang---screen destroyed and set with it.
A few models the back cover has to be removed but that is rare.
Nov 04, 2012 | Toshiba REGZA 47HL167 TV
How do i get the stand off so that i can mount the tv on my wall
Lay down the tv picture screen on a soft flat surface.Check all the screws holes and take out all the screws.Take ur hand holding on to the tv and base stand tight.Pushes in and out few times.The base stand should came wright out..
Dec 24, 2010 | Toshiba Regza 42RV535U 42 in. LCD HDTV
I have a Toshiba Regza 42HL67US that I want to wall mount...how the heck do you get it off the stand?
First you should lay the unit face down on a blanket or the like, being careful NOT to damage the screen. I don't have one in front of me right now but if memory serves well, there is a plastic cover on the back side of the base that you can pop off giving you access to the base mounting screws. Remove the 4 screws and viola, the base should slide off.
May 06, 2010 | Toshiba 42HL67 42 in. LCD Television
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the five screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
How do I remove the stand from a Toshiba TV 19DV616DB
Mine isn't exactly the same model (I've a Toshiba Regza 32AV615DB) but on mine there are 4 small black screws at the back of the TV, near the lower edge. They're recessed into channels and quite difficult to see. Remove these 4 screws and you can lift the TV off the stand. Good luck.
Jan 15, 2010 | Toshiba REGZA 47HL167 TV
How do remove the base on a toshiba 42XV540U?
Dec 06, 2009 | Toshiba REGZA 42XV540 42 in. HDTV LCD TV
Im wanting mount my 37 in toshiba regza but i can figure out how to take off the bottom brace that supports the tv as it stands. i have taken off all the screws but the brace or base still wont come off.
Nov 10, 2009 | Toshiba REGZA 47HL167 TV
I have a 52in Toshiba flat screen that I want to take the base of of so that I can mount it on the wall. The model number is 42XV540U.....I have removed all the screws from the bottom of the base of the...
Nov 09, 2009 | Toshiba REGZA 47HL167 TV
Removal of stand
There are 5 screws in the back of the TV, immediately above the stand. From the stand, they are at the 10:00, 11:00, 12:00, 1:00, and 2:00 locations. If you remove the screw, and find a washer with the screw, then it's probably the right one. Once all 5 screws are removed, the stand slides right off the bottom. Unfortunately, once the stand is removed, the opening is left in the bottom. It's not too bad since once it's mounted to the wall, it's not high enough to see the bottom of the TV anyway. Good luck!
Aug 09, 2008 | Toshiba REGZA 47HL167 TV
Toshiba REGZA 42RV530U 42 in. LCD HDTV Logo
249 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
