Question about HP LaserJet 8000 Printer
How do you clean and/or align printer heads on an HP 8000
  • 277 Answers
Laser jets dont use printer heads, they're only found in inkjets. If you have a problem with the quality of the printout with your laserjet, then you may remove the toner assembly (usually accessible from the front cover) and also see the fusion assembly. The drum may be dirty so you'll need to clean it up with a soft cloth, and de-magnetize it with the corona wire (there should be a slider next to the drum, probably marked with a non-black handle, so you can easily spot it). If there are some dark spots on the printout that come up at the same place on every printout you'll need to go with the cloth cleanup approach.
Posted on Jan 01, 2011
After installing new ink cartridges, when printing black and white, every 4th line of text is only partially printed
Some of the black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 15, 2013 | HP Officejet Pro 8000 Wireless InkJet...
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
I have an hp 8000 and it is printing blue in place of green
Use the software the printer came with and clean the print heads
Aug 05, 2012 | HP Officejet Pro 8000 Wireless InkJet...
HP 6180 Print Problem: I'm getting horizontal streaks when printing either in colour or black, Have cleaned the heads through the printers tool box and ued both levels of cleaning. Also aligned the pr
Fill an old black cartridge with hot water and scan and copy something with a lot of black on it. cleaned out my black ink clog after about 12 copies. Put new ink in and it's working fine. Oh yeah, use a syring minus needle to fill lower o-ring on back of cartridge.
Dec 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
Will not proceed with reallignment--says to insert paper and press ok but then it doesn't do it.
This device having auto alignment Technic,If print heads are clogged it will not print align page properly result alignment will not completed. In this condition it will ask for align print heads when ever printer switched on. To over come from this situation clean print heads fist, manually or though tool box, then try for align. If printer heads are out of health condition replace faulty print heads then perform align process.
Oct 27, 2011 | HP Photosmart 3210 Printer
Hp 8500 printer stuck in continuous cleaning and alignment loop after replacing cartridge
Printer wont do the alignment process if we replaced the cartridges, might be removed/re inserted the printer heads, then ply it process the alignment, if the print head nozzles are clogged, alignment process wont completes..
>Remove the print heads clean the nozzles with tissue paper gently at nozzles.
>borwse this link & see how to clean the print head,link:http://www.youtube.com/watch?v=ZAwYIbjswV0&feature=related
>Install the printer heads do the alignment..
> if not completed check which printer head clogged, replace the print head.
Oct 04, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro L7780 all-in-one, Windows Vista, set up as a wireless network printer, prints multiple copies of test page and also other documents, when only one is selected both at the computer and...
this is a simple problem, the technology that printer aligns its print head automatically by the reading the align page, if your printer head are not in good health/clogged align print wont come properly result align pending..When printer gets power on its prints align page till align completes. Go to tool box in system all programme, perform clean print head, check the quality of printer outs then ask to printer to align.. if its not completing replace print heads..
Sep 10, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
The printer is not printing all letters clearly. I want to clean the printing heads to see if this will help.
To clean the print head from the control panel
1.
Load letter, A4, or legal unused plain white paper into the input tray.
2. Touch Setup on the display.
3. Touch Tools.
4. Touch Clean Print Head.
The HP Photosmart cleans the print head and prints a page that you can recycle or
discard.
To clean the print head from the HP Photosmart Software
1.
2. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
The Printer Toolbox appears.
3. Click the Device Services tab.
4. Click Clean the Print Head.
5. Follow the prompts until you are satisfied with the quality of the output, and then click
Done.
If print quality still seems poor after you clean the print head, try aligning the printer.
If print quality problems persist after cleaning and aligning, contact HP support.
Mar 18, 2010 | HP Photosmart D7460 Printer
Ive lost my owners manual, how do I run the printer heads through the cleaning process?
you can get the manual from http://h10032.www1.hp.com/ctg/Manual/bpu70241.pdf
However cleaning is usually done through the Printer Preferences menu using the printer services. You either use align print heads or clean print heads function.
Dec 19, 2009 | HP PSC 2410 All-In-One InkJet Printer
HP Officejet Pro 8000 Printer goes through motion of printing but page comes out blank
your pint head dirty. so pls clean with wet close. if not work try soak with warm water until all dry ink gone pls be carefull when you do that make sure your print head dry before you use again.
Aug 10, 2009 | HP Photosmart 8250 InkJet Printer
HP LaserJet 8000 Printer Logo
330 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
