SOURCE: Im trying to install an
I just searched Google for about 25 minutes and found a helpful wiring diagram that matched my car's radio wires.
SOURCE: 86 buick century
you need a wiring kit available at mose fine mass merchantes - best buy, circuit city, fryes, walmart etc.
One end will be bare wires to attach to the harness from the radio... the other end will be slots to plug the 3 connectors into.
Metra part # 70-1858
Looks like this...
http://cgi.ebay.com/GM-88up-Radio-Wire-Harness-GM02B-70-1858-Chevy-GMC-Olds_W0QQitemZ260293098000QQcmdZViewItemQQptZCar_Electronics_Installation?hash=item260293098000&_trksid=p3286.c0.m14&_trkparms=66%3A4%7C65%3A15%7C39%3A1%7C240%3A1318
SOURCE: need the color codes for the factory harness
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
there ya go. let me know if that helps ya.
SOURCE: i need to replace a speaker in my buick cetury how
ok before i start if one factory speaker blew and your planing on replacing them all with a after marker speaker this is what you do.
remove the door panel then with that gone you should see a speaker just take it out the factory speakers
may have a clip just cut it off and figure out witch one is positive
and witch one is negative and if you hook it up wrong it wont hurt the
speaker
its the same way with replacing the factory one just DONT cut off the clip
SOURCE: need radio wiring diagram for
2001 Buick Century Car Radio Stereo Audio Wiring Diagram
I hope this helps (remember to rate this answer).
