Question about Gateway 600YGR 600YG2 450ROG COMBO DRIVE 5502686 or 5503049 CD-ROM Drive
When turning on the laptop it beeps3 times and there is no screen
  • Gateway Master
  • 27,725 Answers
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
hope this helps
Posted on Jan 01, 2011
HP Pavilion dv6 7040 TX Laptop screen on right hand upper corner turns dim and after some time becomes uniform
Being a led screen maybe one or more of them have gone bad
Or if you are lucky just a faulty lcd ribbon cable
Mar 25, 2014 | Computers & Internet
No matter what button I push it beeps3 or four ties.
replace the old batteries ( if your system use batteries, and clean and tight the springs contacts from oxide, dirty, corrosion, use contacts cleaner) .
2) tight and clean the ribbon cables inside from display board, tight and clean the upper and lower connector.
3) adjust the REED switch, tight and clean the connector, and test with multimer for open or faulty see the diagram attached.
Oct 21, 2013 | Nordic Track NordicTrack T5 zi Treadmill
White screen
Do you always shut down and unplug the laptop when not in use? Has it been cleaned recently? Fan, Vents, heatsink? Has there been ANY damage? It sounds like your Graphics Adapter. screen, Inverter, is going? Have to say exactly. Does the Laptop Overheat?
May 12, 2013 | Dell Inspiron 1545 Notebook
Toshiba Satellite A505 - Most of the time when I turn it on the screen is grey, with no text.
This sounds like a bad display on the laptop. Hook up an external monitor to the vga port on the laptop. You may need to toggle the display to output to the external monitor. This is generally accomplished by pressing the "FN" key + one of the F# keys. Look for an icon that resembles a monitor or it may say LCD. If the graphics display correctly on the external monitor, then you will need to replace the computer screen.
Dec 29, 2012 | Toshiba Computers & Internet
Laptop screen blank all white
Either your LCD Video Cable is not plugged in snuggly or the monitor is slowly going bad. The fact that you can see the images on an external monitors says your Video Graphics Card is working fine. You'll need to disassemble the laptop to get to the cables. Get a quote from your local computer shops, then try the guys at: http://www.generalsystemsconsulting.com Most times they will fix it and ship it back by Fedex or UPS cheaper than any quote you obtained including the shipping.
Mar 15, 2012 | Compaq Presario CQ56-115DX Laptop
Emacine t2042 beeps once-beeps 3-beeps3-beeps once butr does not boot. What the heck does the beeping mean?
Open the cpu cabinet cover . Then reconnect RAM memory to motherboard clean dust from all parts. Reconnect processor and it's fan reconnect pci if any. Reconnect both connection to harddrive. Make sure motherboard is not ground with cabinet cover. then check. Let me know if you need further assistance. Thanks for using FixYa.
Sep 25, 2011 | E-Machines T2042 PC Desktop
Full screen probs with netflix
This has nothing to do with Netflix, you would get the same result with any DVD regardless of its origin. Chances are that is the laptop trying to revert to a screen saver or power save mode during the movie.
Check your laptop's power and screen saver settings. If you are experiencing the problem every 3 minutes or so, your screen saver is most likely scheduled to go on after 3 minutes of inactivity. The same goes for your monitor-- it may try to dim or turn off after a certain amount of time.
To change these settings to a longer delay, go to your desktop and right click. Select "Properties". Choose the "screen saver" tab, and change the "wait:" field to a higher number. Or, just turn the screen saver off by selecting "(none)" under the screen saver dropbox. You may also click "Power" and change the time for "turn off monitor" to "never", or a longer amount of time.
Jan 04, 2009 | Toshiba Satellite M115-S3094 Notebook
Blank Laptop Screen
unplug everything from your laptop unplug the power from the laptop close it and turn it over remover the battery open and hold the on button(battery is still removed) for a 10 count, replace the battery
turn on you can plug the power cord if needed the prob. should be fixed
Dec 26, 2008 | Gateway MX6956 Notebook
When i turn on my laptop, the screen is blank
It seems to be u have problem with ur RAM ..Try to change it
Nov 29, 2008 | IBM ThinkPad R40 2722 Notebook
Screen wont come on
no video on the screen. Reseat the memory one stick at a time in each slot one at a time and try turning on the laptop after each stick reinsertion to see if you get video. If not then the motherboard is bad.
Oct 26, 2008 | Acer Computers>Laptops Aspire 5610-2328 PC...
Gateway 600YGR 600YG2 450ROG COMBO DRIVE 5502686 or 5503049 CD-ROM Drive Logo
89 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
