Question about Fellowes P50CM Shredder
My P56OC-2 shredder seems to be off alignment. The shredder makes a rumbling noise (when turned to the "I" green light) but the shredder barrel is not turning. When I put it in the reverse mode it will turn freely (two cycles) then reverse itself and stop. I have cleaned out the blades and complete inside. Can the blades be off line? If so hopw do I fix. Thanks
  • 3 Answers
SOURCE: Motor runs blades not turn
Sorry about that, there is no gears for that machnie. Have a great day!
Posted on May 09, 2008
danforddan1
  • 192 Answers
SOURCE: my paper shredder powers on, but the blades dont
Look for a wadd of paper jammed up in the blades, it don;t take much to plug them up you can over look this very easely. DFD
Posted on Apr 16, 2009
JayBlair
  • 328 Answers
SOURCE: durabrand shredder model wm6x runs in reverse but not forward
Try cleaning the sensors with a cotton swab and alcohol.
Posted on Jun 22, 2009
FixinFax
  • 3085 Answers
SOURCE: Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Posted on Jul 05, 2009
ZJLimited
  • 17970 Answers
SOURCE: Shredder runs in reverse, but green "ready" lite
Are you try resetting the shreddar? Do it unplugging and waiting for about 20 seconds, then plugging back in. There is most likely something blocking your shred gears preventing it from running in forward motion.
Sometimes the shredder will work in reverse only, must to check in the back side of the circuit board for anything out of the ordinary. Some cases show a hot spot on the back, just opposite a zener diode and a resistor. Considering how these arn't expensive shredders, just replece it.
Good luck.
Posted on May 03, 2011
I have a staples SPL826X shredder and it won`t shredd, but it will go in reverse. can someone help me?
If you can disconnect the power to unit and check shredding blade alignments to see if there is a clog or if the blades are out of alignment and stuck. If there doesn't seem to be a problem with the blades make a visual inspection of the off/on/reverse switch.
Nov 28, 2014 | Staples SPL826X (CrossCut) Shredder
Why is my ID Armor ID-XC200D making a horrible noise when I shred?
kkrenn641:
That "horrible noise" is probably caused by the shredder gears meshing improperly. If you disassemble it again and look carefully at the gears, you will most likely see that some are not mating properly... Usually the motor gear and the first idler gear that meshes with the motor gear. If those two gears seem to be separated a bit, or slightly mis-aligned look carefully at where the motor mounts, and you may see that the plastic "bed" where the motor is mounted has melted from heat from the motor. This is caused by using the shredder too long without letting the motor cool down. You may be able to shim the motor housing to realign the gears, if you have the patience!
Sep 13, 2012 | Staples ID Armor SH2836ID2836 Shredder
It only works in reverse. I cleaned the interior case compartment, but this did not allow the unit to run in "forward mode."
Hello.
Remove the cover, and check the micro switch for alignment. With use, they can get chad or other debris behind them that will not allow the switch to make proper contact. If you have compressed air,blow the switch clear (gently), or use a soft bristeled brush. Align the parts, and put it back together.
Best regards, --W/D--
May 16, 2011 | Fellowes Powershred 420 Shredder
Light is on for "door
The switch for the door is not working properly. Not sure exactly how this model is set up, but the switch could have come loose and needs to be aligned and then tightened or the switch is defective.
May 03, 2011 | Staples SPLS242D Shredder
GBC shredmaster 1150x shredder now runs only in reverse. And when I press the "reverse" button, the green "forward/shred" light comes on, rather than the red "reverse" light....
The first thing that comes to mind is that the switch is faulty and that one of the contacts has come loose and is shorting across the reverse contacts. There is little else that can go wrong with a shredder, so in this case try replacing the switch.
Jan 26, 2011 | Quartet gbc 1150X Shredder
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
Rumbling noise
Time to call GHOST BUSTERS!
Here is a good service!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 22, 2008 | Maytag Performa PAV2200
We have a GE Dishwasher, when it is in the washing mode, it makes a rumbling noise that is coming from the bottom 0f the machine. Can you help? Thanks
Make sure your spray arms are not loose first.If it remains loud you may have something caught in the food shredder area that is making motor strain/rumble.Also make sure to look under the machine to see if anything(water line-Drain hose) is touching the motor which will sometimes make some unusual sounds.
May 19, 2008 | Dishwashers
Fellowes P50CM Shredder Logo
20 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
steve morris
steve morris
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
