Question about Kenmore 57029 Side by Side Refrigerator
No water from door ice maker works fine - Kenmore 57029 Side by Side Refrigerator
    President:
  • 1,891 Answers
Either the water line is frozen or the water valve has failed . most use a dual valve and the solnoid has burned out . replace the water valve and the problem should be solved mm hope this helped feed back pls ..
Posted on Jan 01, 2011
Testimonial: "That was it!!!!!!!!!!! Thanks!!"
  • rich r Jan 19, 2011
    what was it was it frozen or was it the valve?
LG LFX25976ST refrigerator water in door but no water to ice maker
Check for 120 V at valve when it is supposed to be filling
Apr 01, 2013 | U-Line Refrigerator Ice Maker
Ice maker does not make ice
Is the freezer freezing the contents good?
Nov 27, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
No ice being made. The water is not eing supplied to the ice tray. The water dispenser in the door is working fine.
Well since water is making it to your door the line itself is functioning. You might want to check and see if the fill tube to the ice maker is frozen. Also try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. If it does then the ice maker is at fault.
Mar 19, 2011 | Refrigerators
Ice maker has stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
689sshg
May 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
heatman101
sfhgsyw54
Mar 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker goes through the process but no ice is produced water
If you're not getting water to the ice makerTry swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow. ice maker
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker been working fine, just stopped?
If no ice is being made at all it is probably one of three problems. The ice maker itself needs replacing. The water inlet valve needs replacing. Or the freezer is not 10 degrees or less. You will need to test the water valve solenoids. If you have water in the door then there will be two solenoids. One for the ice maker water and one for the water in the door. They are both mounted on the same assembly. The easiest way for you to test is with a meter. You want to check for continuity on the solenoid for the ice maker. If no continuity, it is bad. If you have both water in the door and ice maker and no meter you can swap the two quick disconnects on the two solenoids and then see if you still get water from the door by now using the other solenoid. If you do not, then you know that, that solenoid is bad. If the soloind is good then you probably have a bad ice maker not calling the ice maker fill valve to allow water.
Jan 10, 2009 | Maytag MZD2766GES Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
227 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
