Question about Da-Lite Complete FastFold Portable Front Screen 76 x 10 DAMat Projector Screen
I have just discovered a 3 a 2 inch tear in a front projection screen, does anyone have any recomendations on how to repair it. Thanks.
  • 457 Answers
A repair would greatly depend on the damage. In general, a patch applied from the back of the screen is the normal procedure. A firm piece of cloth, i.e. fine woven linen cut to the size of the tear plus one inch on each side, glued from behind with a flexible glue (i.e. Pattex Power Glue Repair Extreme or similar). Do not use one-second industrial glue, you'll need time to adjust the edges.
Make sure any fibers sticking out from the edges of the cut go towards the back of the screen, so the surface looks smooth later. Give enough time to dry.
If you are lucky, the edges of the cut close nicely and become neigh invisible from the front.
If screen material is missing, don't push the edges together, it will only result in bends. Instead use a white professional paper repair putty to fill in (check paper shop with artist's equipment, they are the most likely candidates to find such stuff). You may have to mix in a little paint to match the colour of the screen. Try out first without applying the stuff to the screen, until you get a sufficient match. Apply slightly more putty than needed to close any gaps. Use a fine abrasive paper to smoothen the transitions. If you want a near perfect result, use abrasive paper in a granularity matching the screen's surface to get the same texture. Recommendation: try out exercise on a piece of paper first. This stuff is suited for small repairs only, but does wonders if applied properly. It is normally used to repair damages to valuable books.
If material is missing in more than two or three millimeters in size, I doubt you'll get a completely unnoticeable result, but that cannot be helped.
Posted on Jan 01, 2011
  • joshkpete
    joshkpete Mar 02, 2012
    Can you recommend a brand of paper putty? A quick google search for 'white professional paper repair putty' isn't turning up much.
My boyfriend was bringing our new 60 inch television home. he put a tarp over it and it scratched the screen. what can we do???
There is not much you can do besides replace the screen. Go to www.encompassparts.com There are 2 screens together on the front. The outside screen is the lenticular sceen and the inside screen is the fresnel screen. Thanks
Oct 29, 2009 | RCA P61927 61" Rear Projection Television
60 inch fresnel screen
Your best bet is to try local TV shops to see if they have any and look on e-bay you may find one there or Place a add in Paper on wanted for tv ?You never know when someone has the same set as yours and lighting hits and most shops sell used screens ,ect what ever is good lefted on set.Have you look under repair service that is listed here on FixYa? Contact some of these shops listed on it! maybe someone has it.Good Luck .
Dec 18, 2008 | Philips Magnavox 9P6034C 60" Rear...
Behind grill?
this is the little black box made from epoxy molded is about 3 inch by 3 inch behind the front grille you will have to remove the cover in the front once the grille is off it is 1 of the first things you will see. if you look close the controls are marked with r,g,b. you want the screen control it should be the 1 lowest on the box 3 in a row r for red g for green etc.
Oct 08, 2008 | Sony KP-46WT500 46" Rear Projection...
Streaks
It's called tearing and it's likely in the HV circuit, possibly the FBT or splitter. Won't go into any greater detail than that, other than to say it's time to call the technician. Voltages in that circuit can make you VERY dead...
Bill
Mar 18, 2008 | Panasonic PT-53WX42 53" Rear Projection...
TV Repair
I HAVE THE SAME PROBLEM. DID ANYONE HELP YOU?
Mar 11, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 32 inch wide screen tv model 1001940732p10423
Common issue with Philips projections is contaminated cooling fluid in most likely 2 of the 3 CRT's. This will require a technician to clean and refill.
Jan 20, 2008 | Philips 60P8341 60" Rear Projection...
60 in.rear projection Philips Magnavox
Problem solved.
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.  To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here. http://www.magnavoxhelp.com
Nov 07, 2007 | Philips Magnavox 9P6034C 60" Rear...
Picture problems
Sounds like a problem in the main power regulator circuit, such as a bad capacitor or regulator IC or transisitor. There are no user serviceable parts inside these sets and every thing is soldered into place. I recomend that you call in a trained service tech to assist you with this repair.
Sep 25, 2006 | Proscan PS50670 50" Rear Projection...
Da-Lite Complete FastFold Portable Front Screen 76 x 10 DAMat Projector Screen Logo
1,648 people viewed this question
Top Da-Lite Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Tony Mitri
Are you a Da-Lite Office Equipment and Supply Expert? Answer questions, earn points and help others
