Question about Dell Dimension 1100 PC Desktop
Where is the sound card located in a dell dimension 1100?
  • 536 Answers
The sound card is integrated into the motherboard of the system. It is not a separate card. Two usual things that are of interest are disabling the onboard sound and installing the driver to be able to use the onboard sound. I cover both below:
If you want to install a new card, you need to disable the on-board sound card. You do this with System Setup. This is described on page 83 of the user manual (click here for the manual)
Entering System Setup
  1. Turn on (or restart) your computer.
  2. When the blue DELLTM logo appears, press immediately.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then shut down your computer (see page 47) and try again.
Select "Integrated Devices" and then select "Sound". You will be given the opportunity to disable the onboard sound capability so that i does not interfere with your new sound card.
Make sure that you Save and Exit from this setup utility to save your choice.
If you are trying to get the onboard sound card to work, then you will need to download the driver for this specific computer from the Dell support web site here: (Click here)
Select your version of operating system from the drop-down and then find the driver for the onboard sound card for your computer.
Posted on Jan 01, 2011
    Brigadier General:
  • 8,909 Answers
As usual, on board sound and graphics. So it hasn't actually got a sound card. If you wish, you can dissable the onboard sound and fit a nice card of your choice.
Hope this helps.
MPN DIM11P4MIN Key Features Form Factor Micro Tower Processor Intel Pentium 4 2.8 GHz Installed Memory 256 MB (DDR SDRAM) Operating System Microsoft Windows XP Home Edition HDD Size 80 GB Optical Drive Type CD-ROM • CD Burner Processor Processor Type Intel Pentium 4 Processor Speed 2.8 GHz Processor Manufacturer Intel Motherboard Bus Speed 533 MHz Memory RAM Technology DDR SDRAM Installed RAM 256 MB Max Supported RAM 1 GB Supported RAM Speeds 400 MHz Installed Cache Memory 1 MB Technical Features Integrated Input/Output Ports USB 2.0 x 6 • Serial Port x 1 • PS/2 Mouse x 1 • PS/2 Keyboard x 1 • Parallel Port (ECP/EPP/SPP) x 1 Expansion Bays 2 x 5.25" (External Access) • 1 x 3.5" (External Access) Expansion Slots PCI x 3 Power Configurations ACPI/APM Power Management Hard Drive Hard Drive Capacity 80 GB Hard Drive Interface DMA/ATA-100 (Ultra) Hard Drive Rotation Speed 7,200 RPM CD / DVD Optical Drive Type CD-RW Optical Drive Read Speed 48x (CD) Optical Drive Write Speed 48x (CD-R) Optical Drive ReWrite Speed 32x (CD-RW) Audio / Video Graphic Processor Intel Extreme Graphic 2 Networking Networking Type Integrated 10/100 Network Card Data Link Protocol Ethernet • Fast Ethernet Dimensions Width 7.25 in. Depth 16.75 in. Height 14.5 in. Weight 23 lb. Warranty Warranty 1 Year Miscellaneous OS Certified Microsoft Windows XP Home Edition • Microsoft Windows XP Professional Product ID 28965079 Family Line Dell Dimension
    President:
  • 2,992 Answers
The sound is integrated onto the motherboard in this model, it isn't a separate card.
4 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: dell dimension 1100 multimedia audio controller xp
Go here for all your drivers.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_CEL_1100&os=WW1&osl=en&catid=&impid=
Please rate this solution
Posted on Jan 16, 2009
  • 64 Answers
SOURCE: Add NVida FX5500 Graphics Card - Dell Dimension 1100
If it gives no signal, the card is defect.
Posted on May 16, 2009
rvause
  • 12 Answers
SOURCE: Dell Dimension 4600 creative sound blaster card
It sounds like you may have broken your sound card. I had the same problem when I tried to digitise my old 4-track recordings.
I tried the broken card in another PC, found that it was not working, so I went out and bought a new sound card.
Posted on May 17, 2009
Connected a dell dimension 1100 to tv how do i get audio
Assuming you are using the integrated video card there should be a audio port on the tv near the VGA port. You will have to a cable with 1/8 mini stereo jacks to plug into the pc and the TV.
Aug 30, 2012 | Dell Dimension 1100 PC Desktop
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
Nov 20, 2010 | Dell Dimension 1100 PC Desktop
I have an older Dell dimension 1100 desk top and want to add a pc
Sure, if you are using XP, you should have no problem installing a second video card.
Here is a link to a dual head video card if you need it... http://www.newegg.com/Product/Product.aspx?Item=N82E16814133233
Hope this helps, if so please rate my solution accordingly. Thanks, David
Mar 19, 2009 | Dell Dimension 1100 PC Desktop
Dell Dimension 1100 PC Desktop Logo
274 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
