Question about KitchenAid Dishwashers
KitchenAid under counter dishwasher KUD124SE leaving food residue mainly in upper rack dishes. Suspect something in pump. Is it easy to take apart pump and get whatever is inside?
  • 188 Answers
SOURCE: Dishwaher does not clean, upper rack
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Posted on Mar 13, 2009
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
aborcass
  • 2651 Answers
SOURCE: Upper Rack not cleaning
id try removing hte lower filter plate . 5 torx 15 screws will gain oyou acess to lower sump and 2 more torx screws that will acess you the chopper assy, prhaps filled with debris not allowing good water flow,
Posted on Mar 25, 2008
  • 161 Answers
SOURCE: upper rack dishes dirty
Is it filling with enough water. Look or if you don't know how much water is supposed to be there , Just add a gallon of hot water to the machine after it fills. If this solves the problem check the filter in the fill valve or replace the valve.
Posted on Jul 05, 2008
  • 833 Answers
SOURCE: Food left on dishes
Scrape your dishes of food.  Dishwashers remove whatever is left.
Posted on Nov 26, 2008
Help! The dishes on the top rack of my kitchenaid dishwasher (KUDS01FKPA0) don't get clean. this problem started last year, and two different things may be happening. A guy replaced a part (a screen with a...
The part he replaced (chopper) is a common problem with this particular machine. If he has removed all residual food particles from the machine, and you have done your part to rinse them thoroughly before loading, I doubt you have the same issue. There could be other possibilities. One: The water inlet valve could be restricting, thereby not allowing the the proper amount of water into the machine. Two: The internal pump impellers may be worn, and not propelling the water upward enough to reach the top rack. Hope this lends a little insight.
Nov 04, 2013 | KitchenAid Dishwashers
We have a KitchenAid KUDIO1ILBL2 built in dishwasher that came with our home. First of all the bottom dish rack is falling apart and we'd like to replace it. Also when we wash something strong...
The part number for the lower rack is 8519681 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
As far as cleaning the filter this tip i wrote covers how to clean that pump asm.
http://www.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
In addation to cleaning the filter as regular maintiance a cup of white vinegar in cup in the upper rack and run the dishwasher on a normal cycle helps to clean build up in the tub.
GENE
Sep 11, 2011 | KitchenAid Dishwashers
Maytag model no mdb8951aws. My dishwasher doesnt clean properly. There is a residuesomehing like food stuck inside cups & bowls specially in upper rack .i dont stack dishes.tried everything but no...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
][\][\0-0-
Jul 05, 2010 | Maytag 24 in. MDB8951AWS Stainless Steel...
My dishwasher leaves white residue on cups of the
heatman101
Feb 15, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
Dishwasher not washing and leaving residue on dishes
We have the same problem with the soap dish. I found that we have to be careful how the dishes are in the bottom rack. Sometimes the dishes will block the cover on the soap dispenser and keep it from opening.
Jul 12, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Residue and food particles left on dishes in upper rack.
Check the inlet screen at the bottom of the dishwasher that could impede the flow.
Otherwise the pump may be to blame.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore HE2 Plus Front Load Washer
Dishes not getting clean
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Mar 10, 2009 | Maytag MDB6000 Dishwasher
Kitchenaid, new dishwasher, stopped cleaning top rack dishes
The problem most people encounter with dishwashers is a simple inability to get the dishes clean. There might be stuck-on food or residue from the detergent. A water pressure problem may be the culprit. You may need to replace the water intake valve. Another common problem is mineral build-up. If your house has hard water, the mineral build-up can clog the water jets. Clear each jet with a wire or pin, and run an empty load with some vinegar in the detergent dispenser about once a month.
Sometimes, the dishwasher has problems draining properly. There could be a clog in the drain hose, or a problem with the pump. It's also possible that the dishwater is getting too sudsy, and sensors in the washer aren't detecting the soap foam as water. This causes it to shut down the drain cycle too early. Just use less detergent.
Feb 02, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Dishwashers Logo
274 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
