Question about Denon AVR-1804 Receiver
I have a Denon AVR-1804/884 receiver. The TV/DBS and V Aux work fine and I get sound from my zone 2 speakers which are in the bedroom. The problem I am having is with the Sony Blu-ray Disc player. I get sound from the main speakers when using the player and set to DVD/VDP, but no sound or very faint TV sound when Zone 2 speakers are on and set to DVD/VDP or any other source.
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
SOURCE: Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
Posted on Aug 06, 2008
  • 10 Answers
SOURCE: Playstation3 and Denon AVR-1804
If you don't have a user guide, go to:
usa.denon.com From there, you can click on Support and search for archived info...you will find a pdf there.
Of your five plugs, a red and white next to each other will plug in to the audio in on your denon (Red is for Right) I would use something like the VCR-3 pair on the left side of the rear panel. The other three, Red Green and Blue are for Video Component In on the denon; Use either Video-1 or Video-2 in the component section on the right half of the rear panel.
At his point, it will be best to look at the manual, because you will have to pair the two items together in the menu system. It takes a little patience but isn't too hard.
Good luck.
Posted on Sep 05, 2008
SOURCE: Denon AVR-2105
If the Cd is wired digitally, it will only play through the main zone, because the Denon cannot convert down to RCA to cater for the zone 2. If you plug RCAs from Cd to Denon, Main zone will STILL play from digital, and RCA connection will allow zone 2 to play Cd from RCA input....same with dvd, Satellite Blah blah... no stress, any nasty RCA will do if you want to try before you splash out on really costly cables...perhaps you can help me...want to run AVR 2105 with 2 speakers in zone 2, manual says cant do it - only ably to surround back or biamp...dont want either, dont have stereo yet to try it out...did you have any trouble with that?
Posted on Dec 03, 2008
  • 33 Answers
SOURCE: Denon AVR-2803 Zone 2 sound source
You have to switch your remote into Zone 2 Mode. It will be an option on your remote. Once you put it in that mode, you can change the source just as you would Zone one.
Posted on Jan 25, 2009
I have denon avr 987 receiver i messed up settings somehow. when i have receiver set to dolby digital tv i get sound, but no picture. if i switch the setting to DBS i get picture buy no sound. what did...
Are your DD TV and DBS referring to the same source device or are they separate, say, cable Box and Sat Box?
Start over with the digital audio assignments for wherever you plugged in the digital audio cable from (guessing) your Cable TV box (recommended as "TV" is not usually a great source for audio).
The manual:
http://www.retrevo.com/support/Denon-AVR-987-Receivers-manual/id/696dj079/t/2/
You might also want to define the specific cabling of things if more is required. Exact point-to-point paths and cable styles for audio and video.
Dec 31, 2010 | Denon AVR-987 Receiver
Denon 1910 Zone 2 no sound
Typically, Zone 2 is for a different program than the one you're hearing in the main listening room. You can choose any source for Zone 2 EXCEPT a digital one.
Dec 29, 2009 | Denon AVR-1803 Receiver
Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Jun 28, 2009 | Denon AVR-2106 Receiver
Jan 25, 2009 | Denon AVR-2803 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
No television sound from denon avr-3000
TV has Component input (Green,Red,Blue) connect as follows:
1. Connect Component Video and Audio cables from the Cable box, PS3, DVD or Sat box to thea Component Video and Audio input on the Denon (TV/DBS, DBS,VCR1 VRS2, VDP or DVD).
2. Connect a Component Video cable from the Denon to the TV Component Video input.
3. If you do not have a cable or sat box and have a cable from the wall to the TV you must take an RCA(Red&White) audio out of the TV to an input listed in #1
Nov 21, 2008 | Denon AVR-2106 Receiver
May 24, 2008 | Denon AVR-1803 Receiver
TV/DBS No Picture
please apply a spray over your selection switches and press it many times.-check for mute not on.repeat speaker setup and confirm all speaker are on-
May 14, 2008 | Denon AVR-1706 Receiver
Denon AVR 883 Audio glitch
More than likely the protector circuit is getting activated... You can't go below 6 ohms on the surround back which means you need 12 ohm or higher speakers for outside (since the two outputs for surround back/zone2 are in parallel). As a simple diagnostic test, disconnect one speaker and see if the sound survives longer than 2 seconds.
Mar 26, 2008 | Denon AVR-883 Receiver
Zone 2 Problem
Yes and no. You can get some digital signals to go to zones 2 & 3 but only PCM ones, Analogue always goes. I have a Denon DVD player connected to my 4306 with a denonlink cable. I had to connect RCA Analogue cables to the DVD input to get the sound to come out on Zone 2.
May 02, 2007 | Denon AVR-4306 Receiver
Denon AVR-1804 Receiver Logo
144 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
