Hi, If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat. check out this electric no heat tip... heatman101
I'm not familiar with this particular dryer. However, I've worked on another dryer with a similar problem. That dryer had a problem with its thermostat. It failed in an open circuit condition. That means it couldn't pass current to the heater, but everything else worked. I replaced the thermostat and it fixed the problem. Here's a link to a web page where I found a thermostat for your dryer so you could see what it looks like and how much it costs. You may have to page down to get to the thermostat.
http://www.ransomspares.co.uk/parts/brands/zanussi/tumble-dryers/tc7102w%20(91609250203)/
If you want to verify the thermostat is bad before you buy a new one you could short it out and see if the dryer gets hot. If you do this, just try it out for a minute or two. Don't let the dryer run for a full cycle or it will overheat and that could be very bad.
I hope this advice helps you out.
