Question about Nintendo Rock Band for Wii
Flashing lights on drum control pad. no connection to system.
  • 112 Answers
You must sync the drums. To do this first take off Battery cover of drums.(leave batteries in) Then press the tiny red button on the front of the wii console next to the sd card slot for 2 seconds. In the battery compartment of the drums, there is a tiny red button that looks like the one one the wii. Press it and they should sync. Now your remote should work.
Please rate.
Posted on Jan 02, 2011
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
The control panel is flashing a L. What does this mean?
Hi.
The model indicated: MDB5651A does not have display and the error codes are shown like flashing lights. If that is your model and problem please just tell me what lights are flashing.
In Maytag with display instead, the L on display means that the machine is control locked. That is not an error message, but a code telling that the machine has been locked by the user (probably by mistake since you are the user).
I quote from Maytag technical documentation:
? If a cycle or option pad is pressed after the controls have been locked, the indicator light next to lock graphic will flash five times. On selected models with a countdown display, the display will flash the symbol "L" simultaneously with lock indicator.
? This option does not lock the door, only the dishwasher controls.
To set :
1. Press the Heated Dry pad for three seconds.
2. An indicator light next to the lock graphic will illuminate when the controls are locked.
To Cancel Control Lock:
2. The indicator light will go off as instructed.
Try pressing the the Heated Dry pad for three seconds. If that doesn't work disconnect power. Connect back and try again unlock (power off does not remove the lock). If that still does not work there may be a faulty part. In that case turn appliance off and give me the full model number.
Start holding down the Heated Dry pad for three seconds. In normal conditions that is enough to get rid of the L and of control lock.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Maytag 24 in. MDBH950AWS Built-in...
Ok so when i turn on my ps3 i see Connect the controller using a USB cable So connects but nothing that even tried to reset the pad, and also nothing that I bought 3 extra cable and an additional pad...
When you are charging your controller, have you tried pressing the ps button, (circular button in the middle) on your controller to synchronise controller to ps3. When charging are you seeing the red light flash to indicate charging?
Hope this helps.
LJ.
Apr 12, 2011 | Sony Playstation 3 (PS3) Console
My Dual Shock 3 controller won't connect with the system
go into you accesory settings and change the controllers designation,change it to number 1, it will get changed from time to time cuz of drums or guitars being designated as no 1(especially mic's).
Nov 20, 2009 | Sony Dual Shock 3 Controller for...
ABS light goes on and off
Sounds like you have loose brake pad linings.
The traction control measures rotational speed between each rear wheel. If your pad lining momentarily causes one wheel to hesitate your trac control will flash. As the ABS detects braking without the brake pedal being pushed, it will flash.
Check your emergency brake pads. They can fall apart inside the drum/rotor combo on the rear. That is where your sensor is for the ABS.
Aug 15, 2009 | 2003 Ford Mustang
Just opened new rock band for xbox360 system won't reconize drums
Have you tried to connect the drums to the console? You do this by pushing the connect button on the console first, which is a little circular button located on the front faceplate of the console next to the memory card slots. The lights on the light ring should start spinning. Then you press and hold the connect button on the drums controller, and the lights should stop spinning. This should connect the drums. If you have tried this already, let me know.
Jan 18, 2009 | MTV Games Rock Band Bundle for Xbox 360
Lights on but no one's home.
Let system sit for 15-30 mins. system cooled down and reset.
Nov 15, 2008 | Whirlpool GEW9250 Electric Dryer
Yellow Toner Light Flashes - won't print
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 22, 2008 | Brother HL-2040 Laser Printer
Nintendo Rock Band for  Wii Logo
189 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
