Question about Canon SPEEDLITE 580EX TTL Flash
Amperege of 580 EX-II
I use Duracell batteries (alkaline) for my Canon 580 EX-II Flash at the moment. But I want to switch to a rechargeable option.
Can i use 2,500 mAh or 3,000 mAh or 4,000 mAh rating rechargeable batteries with my Canon 580 EX-II Flash? Is there any problem with that? What is the maximum mAh rating i can use without damaging the flash? And how long does it take to charge them? Please advise
  • Anonymous Mar 27, 2014
    Canon 580 ex flashes on 7 d and 60 d ..no flash on image
  • 22 Answers
Interesting Question!
The rating in milliamps is a matter of battery capacity and charging rates. The higher the better as you will get more flashes per charge as long as you have the correct charger to match the batteries’ capacity and use the correct charging times. Aside from this issue of duty cycle between charges- this has no effect on the power of the flash unit as to output. This cant burn out or damage the circuitry.
The issue here is VOLTAGE. Most AA alkaline batteries provide 1.5 volts. Most rechargeable AAs provide 1.2 volts. We are looking at a voltage differential of 1.2 volts (a 20% deficit) if 4 batteries are required. This MAY cause slower recycling times in order to attain a full charge for each shot. In SOME units that can cause a bit if overheating due to strain on the step up circuitry.
It so best to check with the manufacture or distributor of you flash unit before purchasing you rechargeable batteries and charger. If you units have a built in charging circuit this can definitely be problems if there is a mismatch in charging rates and voltage. If this is the case be sire to check your manual or with the manufacturer or distributor- there must be a list of compatible batteries.
Ed
Posted on Jul 23, 2008
What type battery for powershotA480
Your camera uses 2 AA batteries, but if you use Alkaline batteries they will drain very fast. You are better off buying rechargeable batteries as you can recharge them several hundred times, cheaper than Duracell or Energizer Alkaline batteries in the long run. If you buy rechargeable batteries make sure you get a high mA capacity the higher the mA which stands for Milliamp Per Hour the longer the battery will last in terms of a charge.
Jun 20, 2014 | Canon PowerShot A480 Digital Camera
Can i use a Canon Speedlite 580 EX II for a canon 550D?
Yes. The 580EX II will work with any Canon digital SLR.
Nov 12, 2012 | Canon Speedlite 540EZ TTL Flash
My canon 580 EX II stops firing even with new batteries
You must disable the 580EX II form using the 4AA.
4AA must be needed when using hv power pack.
Just let the 4AA use & display the LCD panel.
More help, repairs & troubleshooting send me an email.
atdlee@netzero,com
Oct 21, 2012 | Canon Speedlite 580EX II TTL Flash
Canon Speedlite 580 EX (mark 1) 6 years of continuous use - single flash, multiple flash & continuous burst - with rechargeable batteries. All is well, until recently. Now recharge time has quickly...
The capacitor (neck) is no longer hold a charge or charging circuit is going out on a extended breaks.
Save your money and buy ATG's Godox TT685c.
If you buys two, then you got ATG wireless radio ETTL II flashes.
It would cost over $1,000.00+ USD to buy two Canon 600EX II-RT just to do the same with two ATG's.
Apr 25, 2017 | Canon SPEEDLITE 580EX TTL Flash
I purchased a new Canon 580 EX II in July and have used it for 9 weddings, it has been in the Canon shop once, they stated no problems, but the Flash HAS NEVER WORKED RIGHT! It drains the batteries in...
Trust me I have this flash and I LOVE IT, I wouldn't trade it for the world.
Sounds like you have a short somewhere, where did you buy it? Remember Canon gives you a full one year warranty BUT it must be the Canon USA and not Japan model....THAT is where it hurts! Read the fine print, it may be cheaper but that does not mean it will be better.
Even if you have lost your receipt Canon will have you on file, because you registered your Canon product, right??
If you need it fixed, I have the guy for you, but I am located in the San Francisco Bay Area. I am sure you can call him on the phone and he can see if it's worth you having it shipped.
But FIRST CALL CANON they are awesome, and want you happy! And only buy B&H Photo.com they are amazing and NO SALES TAX for online
Keep us posted!
Barbara Yasuhara
www.ystudiophotography.com
Oct 20, 2009 | Canon Speedlite 580EX II TTL Flash
is your master flash set on a camera? The EX II has something that makes it have a 1 second delay when using sync mode, unless the master flash is set on the camera.
Dec 27, 2008 | Canon Speedlite 540EZ TTL Flash
Canon speed lite 580ex 11
I just got the 580 and had trouble with it blinking all the time, the bounce card was out about a mm and I did not realize it, once that was pushed all the way back--voila.
Jun 30, 2008 | Canon SPEEDLITE 580EX TTL Flash
Camera turns itself off while i am using movie mode
Use alkaline batteries like duracell. Digital cameras support only extra duty batteries.
May 04, 2008 | Canon PowerShot SX100 IS Digital Camera
Off camera flash
Here's how I did it with my Canon 430 EX II. The only other Canon flash that can act as a wireless trigger for off camera flash would be the 580 EX II and that is why I love it so much.
The only other way is Pocket Wizards or the Canon wireless thingy, which noone recommends....
Check out the NEW Pocket Wizard Mini TTi it truly does amazing things! And only 199.00!
God luck and let us know how it goes.
Nov 21, 2007 | Canon Cameras
Battery dies right away
You might want to try NON rechargeable batteries, particularly "digitally" rated alkalines. If this won't do it, I'd take it to get looked at.
Feb 14, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon SPEEDLITE 580EX TTL Flash Logo
307 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
