Question about Sony PlayStation Portable (PSP) Console
When i connect i get this message' your wpa key you entered may not be correct"
  • 492 Answers
WPA stands for Wi-Fi protected access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over WEP (Wired Equivalent Privacy) standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
You can correct this problem by entering the WPA Key into your PSP's Network Settings. But before you do that you need to know what your WPA Key is...
Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long.
For minimal security, you can choose 8 characters key, like "iN/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBDm+oMp$nrXj5XPVRTvVA5fpwGSGIRVz4RdQ7V3yl$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
Posted on Jan 01, 2011
I don't know my wpa key
Click on the link below to find the WEP/WPA key of your router.
Find WEP/WPA key
To know your default Router Gateway IP follow the instructions
Click on Start button ( on your PC -> bottom left corner )
Click on Run or Enter in Search button
Type "Command" ( without quotes ) and hit enter key
In the black Window, Enter "IPCONFIG" ( without Quotes ) and hit enter
It will display the network details, Look for Default Gateway, That is your Router IP Address.
Regards,
Sean
Jun 09, 2013 | Belkin Computers & Internet
Where do i find the wpa on my modem?
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
Read more: http://www.brighthub.com/computing/smb-security/articles/44810.aspx#ixzz1FOMsyJkq
Mar 01, 2011 | Video Game Consoles & Games
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | Buffalo Technology AirStation Nfiniti...
How do i connect to internet with ps3, wireless, what is a wpa key?
Jan 02, 2011 | Video Game Consoles & Games
Error code 051099-1
This seems to be a problem with your wireless router. Check to make sure you put in the proper WEP/WPA Security Code. If you aren't sure what I'm talking about...
Jan 01, 2011 | Nintendo DSi Blue Console
Hi i want to have internet on my PSP but it says type your wpa key and i dont know it.
It's a bit different for each router but I can show you how it would look in a regular setting:
Jan 01, 2011 | Sony PSPgo White Console
My Vizio HDtv WIFI shows a good signal from my Linskys router but is "unabke to connect" even though I repeatedly enter the correct pass phrase, what is wrong?
Run the Linksys Wireless Network Monitor by double-clicking this icon 3719-001.jpg at the bottom-right corner of your screen. If you don't see the Wireless Network Monitor icon, click here.
kb_4285-001_en.png Step 2:
Click the Site Survey tab and select the name of your wireless network or SSID, then click Connect. In this example, we used a wireless USB adapter.
NOTE: images may differ depending on the model number of the adapter.
Step 3:
If the software is asking for a WEP key, enter the WEP key on the WEP Key 1 field.
If the software is asking for a WPA-Personal key, enter the WPA key on the Passphrase field
Nov 02, 2010 | Computers & Internet
Can not connect to my netgear wireless network
Hi, are u sure if you are using the correct WPA key. You can check the same by following the steps below:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Connec to the wireless network using this key.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 03, 2009 | NetGear RangeMax WPN824 Wireless Router
When entering a WPA key in the network settings of my HP OfficeJet 6480, how do I toggle from letters to numbers?
When you enter the WPA key, use the appropriate key on number keypad on the front panel. Keep pressing the appropriate key until the desired letter (upper or lower) appears.
Once the correct letter is displayed, wait a second or two and the cursor will move to right so you can enter the next letter or key.
A second option is to connect the printer to your using the wired connection and then open the web interface using the ip address of the printer. Login to the printer then go to the wireless security settings and enter the Pre-Shared Key (WPA key).
It's also a good idea to put a check mark in the "Obscure PSK" option box as an added security measure.
Jun 04, 2009 | Digital Products Hewlett Packard OfficeJet...
Connecting to network
[QUOTE]The exact error message should be:
"Windows was unable to find a certificate to log you
on to the network [SSID]"
Google shows 37 hits with this exact phrase.
This is caused by setting the encryption to WPA-RADIUS instead of
WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.
Switch the encryption to WPA-PSK (pre-shared key) on both ends and it
will work.[/quote]
Jan 16, 2008 | Linksys Wireless-G WRT54G Router
Sony PlayStation Portable (PSP) Console Logo
234 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
