Question about Toys
I have a nincoair 180 alupro helicopter. it worked well for a day then seemed to loose its signal. it works at very close range (8" inchs) then goes haywire.
Check the infra-red diode in the transmitter one of them is probably bad I have the same problem
Posted on Mar 15, 2011
No signal to the helicopter
Check all wires to the servos in the copper. They do come loose and get croted, clean your connection and try that, worst case, you may have to replace the servo. Must hobby stores have them.
I hope this helps you
Jan 25, 2014 | Syma S026G 7" RC Remote Control...
Tip
Box specs and airspace for 8 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 15 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be a box of 9 inches high, x 9 inches wide, x 9 inches deep. Or 400mm high, x 400mm wide, x 400mm deep. <br />Enjoy! <br />
on May 29, 2011 | Car Audio & Video
Spark plug want fire
Hi, Anonymous if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue, please visit the websites below. Good luck and have a nice day.
How to check for Spark Plug Fire in any engine
How to rule out Spark Plug as your problem
Bajaj Avenger 180 DTS 2007 service manual DOWNLOAD FREE FULLMANUALS COM
http://www.marutibajaj.com/pdf/avg-180.pdf
Aug 06, 2013 | 2007 Bajaj Bajaj Avenger
My 90 cc is not getting any spark
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
How to diagnose no spark situation on motorcycle
Apr 02, 2013 | 2007 Bajaj Bajaj Avenger
I bought a World Tech Toys ZX-A68690 helicopter and I cant get it to work. I charged the battery pack as outlined in the operation manual. I installed the "AA" Duracel batteries in the...
Try turning the controller power on ( before turning on the chopper) and then quickly moving the left throttle stick up to the fastest setting and then immediately back to the slowest speed setting...The flashing should stop. This calibrates the remote throttle range.
Turn on the helicopter and you should be OK
Jun 01, 2011 | Worldtech Devices Toys
X107 Mini helicopter does not seem to be taking a charge from USB port on computer. ran coptor for about 2 weeks following recharging instructions... rest, recharge of heli in "off"...
Hi, My X107 MINI HELICOPTER does not receive transmit anymore. It was working fine before. It only flys if I hold the remote control right next to the sensor. If I move it away it loses transmit. Both units have full power. How do I solve this problem.
Jan 27, 2011 | Cobra Electronics Cobra RC 3 Channel Mini...
Loses signal momentarily. Fully charged. One day old. Mid-flight the signal just drops out for a moment. Them it seems that there's a delay in signal reception.
dude in the room that you are flying it in, turn off all electronics especially ur hdtv or regular tv, i had the same exact problem, i found the solution when i flew it in another room with no electronics, i then came back to the room in question (my livingroom) lol and proceeded to turn off everything, and whalaa!! a perfect flght with no mid flight drops!!, hope this helps you man
Dec 23, 2010 | SYMA Toys industrial New Syma S107 Radio...
My helicopter flew for a few seconds and then feel to the ground. It seems as if the controller does not work with the helicopter
Check your battery pack to see if the controller lost power or the battery pack in the RC ARF to ensure that, the copter can receive.
Dec 22, 2010 | RC ARF Falcon 40 Helicopter
Taking a close up of an item 6" long is not
According to the manual, the C310 has a fixed-focus lens with a working range of 0.85 m (about 33 inches) to infinity. So, anything only ten inches from the camera will be out of focus.
Nov 06, 2010 | Kodak EasyShare C310 Digital Camera
Open Questions:
Toys Logo
275 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
