Fix error 651 on windows 7 - Computers & Internet
  • 492 Answers
In windows 7, when you try to connect using your PPPoE connections, you may be faced with the following error: Error 651: The Modem (or other connecting device) has reported an error.
These connections would work just fine with Windows XP or Windows Vista PCs.
Again, you are not alone, this seems to be a known bug in Windows 7 that is being worked at. However, you can workaround this problem.
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip). This should help!
Posted on Jan 01, 2011
Xerox workcentre 6015 ni error code 092-651
Printer CM205 b error code 092-651
Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Thank you for the help.
Apr 12, 2014 | Xerox WORKCENTRE 6015/Ni Color
How to solve ERROR 651 problem in windows 8 for ADSL modem
Here is the link that explains the issue:
Windows 8 1 broadband error 651 video inside
The solution from my point of view would be to not use IE 11
Jan 04, 2014 | Microsoft Windows Vista Ultimate Edition
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
Gateway dx4720-03 error 651 can't connect to internet
hello,
This error"Error 651" is caused by this file raspppoe.sys you can find it in c:/windows/system32/drivers/ rename it(raspppoe_something.sys) and copy the new file from a friend pc that runs vista .
Jun 10, 2012 | Gateway Computers & Internet
What is error code 651?
I have fixed mind through following steps, OS Windows 7. This works if you can still use cable internet, so that system can download the driver.
In my case there was no wifi utility, no connections detecting, no bars IIII.
Solution:
Please note it is mostly to do with your network drivers, if you go to device manager under the network adapters, you will see network controller marked in yellow. Dont worry.
To make your wifi connection work please complete the following steps:
Goto:
Device manager > trouble shooting ( column 3 , second last row )
Now under " Hardware and Sounds" heading go to configure a device.
It will start trouble shooting automatically, and try to download and install the right network control driver.
My system is using: Realtek PCIe FE Family Controller and after downloading the driver. I have now following installed.
Realtek RTL8191 SE802.11 b/g/n Wifi Adapter ( this was missing )
Now when I go back to device manager I have both are functioning and after reboot I automatically connect to the wifi. So everything is fine.
So my advice to all whatever make is your PC / OS , do go to device manager and try trouble shooting.
For those who have found this solution helpful, please email me: manny.nlAThotmail.com
Jan 21, 2011 | D-Link DI 514 Wireless Router (DI-514)
I am connected to internet but get error 651
I am assuming you have purchased a new pc with Windows7 and have a DSL internet connection. If so the following tutorial should prove useful. This is a common problem and known bug within the Windows7 framework that they are working to correct. Keep in mind that this fix is only applicable for the Windows7 operating system.
"The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can work around the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system click here to download raspppoe.sys file (unzip)."
http://www.windowsreference.com/windows-7/error-651-with-pppoe-connections-in-windows-7/
Once downloaded and unzipped you may rename the old rasppoe file as mentioned above by right clicking the icon and choosing 'rename'. Then copy the new rasppoe file you downloaded into the applicable folder. You will find this file in the following directory C:\WINDOWS\system32\drivers. Bear in mind, when searching for the file inside the drivers folder, the .sys file extension may or may not be included in the actual name. If the original file is named 'rasppoe' without the .sys file extension in the name, leave this file extension off when renaming and copying as well.
Dec 10, 2010 | E-Machines eMachines Desktop PC
Wireless not working pc told me error 651
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system . If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip)
DO VOTE ME
Dec 07, 2010 | Computers & Internet
Unable to connect to internet on broadband, keep getting error message 651, Win 7. No problem prior to loading Win 7, used to have Vista Ultimate.
This a well known bug in Windows 7 specially when you migrate from Windows Vista to Windows 7.
The cause is a file "raspppoe.sys". This file will be found on the partition you have installed your operating system If it is C: partition then it is found on C:\Windows\System32\drivers.
To fix this bug simply rename it as shown as follows
(1)Rename this file from "raspppoe.sys" to raspppoe.old or any name it any name of your choice.
(2)Once this done simply restart
Nov 11, 2010 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
327 people viewed this question
David Payne
David Payne
