Question about Stanley Bostitch Nail Gun
I have a Bostitch framing gun, I have only used it a handful of times. The framing gun doen't firer a nail, when I hook up the compress air there no leakage of air from the trigger or anywhere else. When I try to firer a nail there is a dischange from exit of the nail gun and the top of the gun thru the vent. Do I have a blown ring?
    President:
  • Stanley Master
  • 1,383 Answers
Most likely only needs lubrication. Remove head and apply silicone paste lube (sold at lowes in the plumbing department) to orings of the headvalve. Pull piston and lube oring. Should be ready to work. Good holiday
Posted on Jan 01, 2011
How do you adjust nail depth on Bostitch N80 framing nail gun?
i think this model has no adjustment. if it does it is on safety tip. if not you can only adjust air pressure.
Aug 05, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
Will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Jun 11, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
May 31, 2009 | Stanley Bostitch F21PL Nailer
Have ism coil nail gun what nails do i use where can i get info about the nailer
Somewhere there should be a model #, I have never seen a ISM.
Most all bostitch roofing coil nails will fit there guns.
Below I posted there website where you can check the info on your gun.
http://www.bostitch.com/default.asp?TYPE=CATEGORY&CATEGORY=BOS_ROOFING_NAILER_STAPLER
Apr 07, 2009 | Stanley Bostitch Coil Framing Nailer
N80sb-1 stanley bostitch framing gun.
Yes your nailer will drive other sizes of nails. For info and parts go to www.bostitch.com and look for the support tab then select service parts. Here you will find parts list and manual. To remove the tva11 trigger valve remove the retainer pin (the pin is 3mm) for the trigger and remove trigger. Next remove roll pin/pins that retain trigger valve. Use heavy glove to catch trigger valve as you apply air pressure to gun. The valve could pop out with great force so try lowering the pressure to gun. Before installing the new valve, check the opening for sharp edges which will cut orings. Good Luck and email if you have more questions.
Mar 14, 2009 | Stanley Air Tools & Compressors
Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Jan 05, 2009 | Stanley Bostitch Coil Framing Nailer
try going to their website -I have several guns and each take at least 4 sizes of nails- yours should be no different- good luck hope this helps
Oct 11, 2008 | Stanley Bostitch N86S 1 Factory...
Stanley Bostitch Nail Gun Logo
589 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
