Question about Grilling
My Polder 601-90 Cooking Thermometer is no longer calibrated, is there a way to fix this?
4 Suggested Answers
  • 78 Answers
SOURCE: How do you change the battery on a Polder Swivel
http://polder.com.p2.hostingprod.com/images/instructions/604_instructions.pdf
Posted on Dec 11, 2010
SOURCE: Polder 891-90 Where can I get
Polder timer manuals appear on following link:
http://www.polder.com/productinfo.html
Typical 891 manual:
http://polder.com.p2.hostingprod.com/images/instructions/891_instructions.pdf
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 28, 2011
SOURCE: I have a polder digital thermometer with two
Timer is not identified for certain.
1) Some Polder timers have in-oven thermometer, and others say not to use thermometer inside oven.
2) The 12453 dual-sensor says inside-oven is ok
3) The 894 dual sensor says inside-oven is ok
4) TM360 dual probe says inside-over is ok
I am cooking a pork crown roast for Christmas it says to cook it at 3:50 for 2 hours however I will not be back for 3 to 3 1/2 hours at what temperature should I cook it so that it will turn out well
Hello, Vicki -
I hope you have a meat thermometer.
I suggest you roast the pork at 250 degrees Fahrenheit, so the cooking time will take longer. When you return home, pull the roast out of the oven and insert your meat thermometer. The internal temperature of the meat needs to be between 140-145 degrees F. If it is not, put the pork roast back in the oven and turn the heat up to 350 degrees F. Check the internal meat temperature every 15 min.
You CAN set the cooking temperature even lower to allow for an even longer cooking time. But NEVER set it lower than 200 degrees F.
Note: Be sure to turn your oven off when no longer needed. Plus, allow the meat to rest 10-15 min. before carving.
Dec 24, 2017 | Cooking
Daewoo nofrost multi flow freezer
Sounds like a gas problem if its new under warranty get it replaced.If its old dont repair,replace it.
Sep 04, 2014 | Polder THM560N FridgeFreezer Thermometer...
Can battery be changed on Polder instant read meat thermometer? If so,How?
Batteries can be changed on almost all instant read thermometers
go to POLDER.COM/ support/
then choose then choose
Thermometers
and then enter your model #.
This should take you to a detailed explanation. In general look at the unit and find the place to gently pry the cover apart. remove the batteries and replace with the same new style.
May 04, 2014 | Polder Home
How do you turn off polder digital thermometer
Sounds like the on/off switch is bad. The simplest solution is to remove
the battery to turn it off.
Jun 23, 2012 | Polder Swivel Head Digital Instant Read...
Polder 891-90 Where can I get an instruction manual for this meat thermometer Thanks
Typical 891 manual:
Oct 31, 2010 | Polder Triple Digital Timer Model 891-90
I have a polder digital thermometer with two probes--but I didn't get instructions with them.. Can I insert the probe in the oven with the meat cooking or use only with the meat out of the oven to test it...
Oct 30, 2010 | Polder Triple Digital Timer Model 891-90
Un even cooking model #790.92314301
Generally, most units are properly calibrated at the factory.  Get an oven thermometer for a few dollars at Ace and place it in the oven and run it at a particular temperature...say 350.  If the thermometer is off more than about 15 degrees after warm up and stabilization...another 10 minutes, most manuals have a way of altering the thermostat settings to compensate.
Nov 19, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
When I cook or bake in my electric oven things are never done in the recommended cooking time. The heating element is working fine.
hi. thanks for the question. does the door seal properly. check that..sometimes the calibration will go off. what i tell my customers to do is.buy a small oven thermometer, that you hang from the racks . then try the oven at 350 degrees .then look at the oven thermometer . and see what the difference is. so lf ,the oven temp is a bit low .cook at 375. degrees. that will make up the difference . no parts needed. cheap fix. thanks the appliance doc
Sep 28, 2008 | Kitchen Ranges
Maytag oven calibration
Maytag single built in oven model cwe9000bcb beeps intermittenly. Reset stops for about 1 minute. Two control panel boards replaced since 2002 with same problem. Can it be fixed?
Dec 18, 2007 | Maytag CWE4800A Electric Single Oven
Grilling Logo
104 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
