Question about General Electric WJRE5500GWW Front Load Washer
On the spin cycle my washer is banging very violently is it off balance? Is that and easy fix?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you may lost or have weak balance springs/rods in you machine, It does take experience to work with and balance machines.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
How do I fix a front load washer that shakes violently on the last spin cycle?
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
Sep 13, 2014 | Washing Machines
Banging drum when spinning
if the drum in the washer klunks/bangs in ANY brand of washer when it is spinning, your load is off balance. stop the machine, re-distribute the wet clothes so that the weight is evenly distributed, then restar the spin. u may have to do this more than once if u did not evely distribute the weight. this is an easy one. just be sure to stop the spin soon as it starts banging. letting it bang thru an entire spin cycle could result in actual damage to the machine. some of the new machines auto shut off at an imbalance so u can correct the problem. think of spinning a top. u unevenly add weights to it then spin it again, it WILL wobble.
Feb 22, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
Washer bangs loudly in middle of spin cycle
Make sure the back spring is still on the back of the tub. That tends to come off sometimes. Check all the other springs while you're down there too. You can balance the unit if you tilt the back side of the washer and then set it back down. it has auto leveling feet. What's happening is once the water is all drained out, the unit will enter the final spin cycle and spin very fast putting the unit off balance so the tub bounces around.
Good luck, let me know if this helped.
Aug 10, 2009 | Kenmore 23012 Top Load Washer
Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
General Electric WJRE5500GWW Front Load Washer Logo
132 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
