Question about SNK Magnavox 32MD357B_37 32 in. LCD HDTV/DVD Combo
My DVD player built in to the TV keeps spitting out the DVD. Any solution to this issue?
My t127dvfd is not keeping the dvd in
Issue with the DVD player. go for hardware fix or try to replace.
Mar 29, 2014 | Televison & Video
DVD doesn't work accepts dvd then says loading...
Hey scowtz, if your dvd is a burned copy or has other file formats that are not the most common, or I should say, basic types then it most likely will not play it. TV/DVD Combo's are made with the most basic formats. If you want to play burned copies I suggest get a dvd player and look for the formats that it plays. Usually the format label is printed on the front of the dvd player. However, if your dvd is an original that you bought from a store and it still does not play it, then its an OEM issue. Meaning you need to return it / send it for warranty / or get a replacement. I hate to say it but these dvd players built in to the tv are not the greatest and very basic so the manufactures do not put much effort in building a good quality ones. (This is only an opinion but I use to work at a home theatre dept. at a major electronic store that I probably should not disclose and these issues were common). Get the stand alone dvd players, some are quite cheap and play wide variety of formats and are actually pretty solid players. I hope this helps. Give me a feedback if this does not help. Good luck.
- Joe
Oct 23, 2013 | ViewSonic N2201W 22 in. LCD TV TV/DVD...
32lg40 built in dvd player disk error
There definatley could be a firmware issue with that TV's DVD player if the model has just been released.  My suggestion would be to bring a couple of known to be working DVD's back to the store and try their floor model as well.  This will be easier than bringing back the TV for the second time.  If this is a problem with the DVD player's firmware, LG should be able to fix it under warranty so I would call them or swap out the TV for another brand instead.
Mar 24, 2009 | LG 32LG40 32 in. LCD HDTV
When I go to put a DVD disc in, the DVD player will not read, it just spits the disc back out and says ERROR.
sounds like a region code issue, try to obtain unlock codes for the DVD player
Jan 25, 2009 | Allegro ABV511
Philips tv with built dvd , dvd keeps coming on,
Initially, try to clean the lens/laser with the use of a CD disc cleaner. Shouold that not be sufficient, pls post back the model number of the TV /DVD unit.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Samsung tv - switch to play a dvd player
All you should have to do is hit the TV/Video button on your remote. It also could be named AUX, or or INPUT. What this does is tells the tv to switch to the input you have the DVD player hooked up to. Otherwise it will keep drafting a signal off of your cable line.
May 31, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
SNK Magnavox 32MD357B_37 32 in. LCD HDTV/DVD Combo Logo
94 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
