Question about LG Washing Machines
The drum is not spinning and the machine stops and has LE on display
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Drum not spinning, seems to be stuck
LE error means "Motor Error" that your machine's motor is faulty and needs to be replaced.
Dec 22, 2013 | LG WM-1832C Front Load Washer
LE Wm1812CW WILL NOT SPIN LE CODE
was it making a banging noise befor it stopped spinning could be your drum has dropped and if this is the case its no good any more hope this helps
Nov 26, 2011 | Washing Machines
My washer is saying LE, what does LE mean? It stopped washing!
Hope this helps.
Jun 29, 2011 | LG Washing Machines
LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Apr 13, 2010 | LG WM1814CW Front Load Washer
When drum starts to turn locks up then will turn one way but not the other.then after 2 or 3 times it will turn the other way then le code comes up
Possibly a bad load sensor ($20 part 6501KW2002A)
For me it was the bearings were shot. Heard
loud noise during spin then the unit stopped and displayed the LE error.
Removed the rear panel then removed the large center bolt. Grabbed both sides of the Stator cover and rocked it back and forth till it came off. Noticed that the drum had been leaking which caused the bearings to break away which lodged in the motor.
Now I'm replacing with diff brand since i'm not sure what all damage this caused.
Pictures posted:
http://www.fixya.com/support/t608508-very_loud_grinding_noise_lg_wm_2277hw
Sep 27, 2009 | LG WM-2277HW Front Load Washer
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
LE fault code for LG WD-1019bd washer
Usually it is the stator at fault with an LE error. I would make sure the cable between the stators windings and hall sensor are ok back to the main control board also give the wires a good tug sometimes the copper breaks inside the wiring insulation at the white connection blocks. Check to make sure theres nothing got trapped inbetween the drum and tub this can lock the drum up and give the fault. After checking all the above i would think it would either be a faulty stator or the main control board has failed. Hope this helps.
Dec 21, 2008 | Washing Machines
Shows "LE" in display.
Machine has a bad motor or "stator" on this machine. It is a direct drive winding on the back of the machine. Remove the back panel, the one bolt removes the rotor then you will see the stator winding, replace it and your good to go.
May 11, 2008 | Washing Machines
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
Washing Machines Logo
199 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
