Question about Ionic Pro 901P2RIP04 Air Purifier
How come the blades turned black - Ionic Pro 901P2RIP04 Air Purifier
Because they are dirty
Posted on Jan 02, 2011
Broken Fan Blade
No usually original equipment parts only.
Oct 03, 2013 | Hunter 30735 Air Purifier
Flair living air purificaion system
here are parts for your air purifier, including the motor and other parts you may need in the future.
AirPurifierRepair.
- just click the link
hope that helps, good luck
Jul 31, 2008 | Ecoquest Flair Air Purifier
How to Clean electric motor in air purifier
replce the mtors as there is nothing in them to clean
May 23, 2017 | Air Purifiers
Want additional cleaning blades to use when cleaning other
Check out Ebay I have seen them for sale there. Type in search bar Sharper Image Ionic Breeze parts. That should steer you in the right direction. Hope this helps.
Dec 16, 2010 | Ionic Pro Turbo Air Purifier - Black
Unit will sometimes make a crackling noise.
Mine does it too, I finally just tried something else when I was cleaning the blades. I took some alcohol on a qtip and with the blades out of the machine I wiped up and down the line wires that are inside that go from the top to the bottom, and also the little balls that are on the bottom of the wires that slide when you turn your unit upside down. It seems to work, I do it every time I clean the blades. scribner062
May 22, 2010 | Sharper Image Ionic Breeze Quadra Air...
Makes a funny sound when turned on
Something is touching the fan blades.
Apr 18, 2009 | Ecoquest Flair Air Purifier
RED CLEAN LIGHT
After cleaning the unit, blue light turns on momentarily then red cleaning light comes back on. Have cleaned and dried unit including the contacts on the end (cleaned with alcohol). Sounds like a common problem, any solution?
Bob
Jun 17, 2008 | Ionic Pro 901P2RIP04 Air Purifier
Ionic Pro Turbo air purifier
i have the same problem after cleaning it it turned on with a sound like frying stuff .and it goes to red light which means clean..but the blades are clean i dont know whats goin on but theres a smell in the unit which i cant tell what kind any one can help?
Jun 05, 2008 | Ionic Pro TURBO Air Purifier
Excessive noise
I found that the buzzing can be removed by blowing out the unit, cleaning the blades and taking a long cotton swab and alcohol to thoroughly clean the corona wire - carefully - don't break it. The wire should be clean enough that the slider/wiper runs smoothly up and down the wire after cleaning. If it drags or is rough to slide, you will still have noise no matter how many times you clean the blades. The wire gets a "crust" on it.
Oct 26, 2007 | Ionic Pro TURBO Air Purifier
Ionic pro won't turn on
Solution, perhaps...
All electrical contacts can get a film on them. Try cleaning the contacts (at the bottom of the blade unit; you should see the three with the blades out) with an alcohol swab (make sure the contacts are dry before reassembly in this case) or a pencil eraser (vacuum the debris out before attempting to start it again).
If those contacts don't make up properly, the unit will think it needs cleaning, even though it doesn't.
Mar 27, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Ionic Pro 901P2RIP04 Air Purifier Logo
49 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
