Question about LG Washing Machines
What is a le code and how do i fix it thanks cathy
  • 1,772 Answers
Sdfsf
sdfSorry to read about your problem, I hope this helps you out.Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Water left in bottom of dishwasher. Dishes clean. When I pushed START to see if that would empty machine, water started leaking from the bottom. I removed kickplate and leak was coming from around bra
Cathy, you need the help of a neighbour with basic DIY skills. A hose may have perished and started leaking or it needs 2 turns of a screwdriver on a hose clip.. Either way you need help.
Dec 28, 2014 | Dishwashers
WHAT DOES ERROR CODE LE MEAN
Good Morning Friend, thank you for your inquiry!
I see that you are receiving error code LE on your Frigidaire washer. However, is it possible that the code is missing characters? I show that LE is an invalid error code. May I have your model number please? You can normally find the serial tag (which lists your model number) on the upper front, as you open the door. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better address the issue at hand. Thank you! - Z
Jul 17, 2014 | Frigidaire ATF6000ES Front Load Washer
Unlock code for adobe reader LE 2.5 for nokia x6
NOkia c5-03 Mobile imei 357925047286064 unlock code Adobe reader LE 2.5.15,.Please Send to my mail satria_ronika@yahoo.com
Sep 18, 2011 | Nokia X6 16GB Cell Phone
I have an LE code how can i reset
Try unplugging the unit for a few minutes. Then plug back in. If not try the Power button. I have an SE code (drainage problem) and my machine stops running altogether.
Sep 05, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Le error code
IE means that it is taking too long to fill up.
May 28, 2009 | LG WM-0532HW Front Load Washer
Hello, I have bought a PFAFF 213 sewing machine with a jammed shaft. I have oiled the machine, but the needle won't move up and down. The machine is very clean inside, indicating that it has been used...
I did fix the jammed shaft - simply by applying some tenacious oil and letting it sit overnight. It is now a fully-functioning machine!
Thanks for your ear and your interest,
Cathy
Apr 03, 2008 | PfaFF Creative 7570
User manual
I have an instruction book for the Ronson9110 now and can scan and email to anyone who requires thanks Cathy
Oct 23, 2007 | Kitchen Appliances - Others
Washing Machines Logo
128 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
