Question about Whirlpool 24 in. DU900PCD Built-in Dishwasher
I ahve a DC900PC dishwasher that is not draining , I cant get to the drain hose, need help, thanlks
  • 4,323 Answers
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Jan 01, 2011
My Kenmore dishwasher wontdrain #665.17002400
did u check drain hose it might be plugged. also some people put in new disposal. disposals come with knock out u need to remov it or it camt drain
Jan 26, 2015 | Kenmore Dishwashers
Bosch shu43c02uc
test this steps and fix it. God bless you
Belt, Water Pump
Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Drain Pump
If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller
The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit
If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve
The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly
If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer
If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose
If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve
If the dishwasher won't drain the check valve might be stuck closed. The check valve is a device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is located in or at the outlet of the pump that the drain hose attaches to. Sometimes the check valve is accessed from the inside of the unit depending on the model.
Check Ball
If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Jul 22, 2013 | Dishwashers
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
First four lights on cycle indicator flash and machine beeps 10 times and then beeps every 30 seconds
I recomend checking drain hose for kinks or obstructions and checking drain pump. most dishwashers will drain first for about 25/30 seconds.Also check the drain hose into the main plumbing connection it maybe blocked.If it cant drain it wont do anything hope this helps.
Feb 17, 2012 | KitchenAid Dishwashers
My bosch SGS3062GB is not draining the water away - the water is stagnent in the bottom of the dishwasher. I ran the rinse cycle and it left about 2.5inches on water in the bottom of the...
Hi
Daniel
Dec 13, 2010 | Dishwashers
Dishwasher won't drain or seems to drain to other diswasher.
possible blockage at sink pipe where the drain hose connects to. the drain hose is attached to the spout on the pipe. remove the clip holding the drain hose to the spout, remove drain hose gently, put drain hose into a bucket and then turn unit on to a cycle. it should start draining straight away.if it does drain into bucket u have a blockage in the spout. put a small screwdriver into spout to unblock . then put drain hose back onto spout with clip and run a cycle. before i forget when and if the water starts draining into the bucket turn off the unit so u can put the drain hose back on. if u need more help please reply. good luck.
Apr 27, 2010 | Fisher and Paykel 23 in. DD603H SS...
Washer will not drain after washing
Check the drain under the sink. They plugged up where the drain hose from the dishwasher goes into the drain. Remove the drain hose, stick a screw driver into the spigot and clear any obstruction. Aside from that, you might ahve someonething stuck in your drain pump, or a faulty pump
Apr 01, 2010 | Frigidaire 24 in. GLD2250RD Built-in...
My the dishwasher will not drain. The pipes are not blocked or kinked. If I shake the pipe the dishwasher will drain. But I cant do that all the time. Any suggestions?
Hi..
If your dishwasher will not draining you need to check this
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Good luck !!!
Regards
PCmania
Jul 13, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwasher states there is a water leak when visually there isn't
Assuming that you have checked under the dishwasher for a leak (through a faulty sump gasket):
Since there is not actual leak, check the following:
-Confirm that the height of Drain Hose connection (sink-Drain Hose) rises greater than 20′ _minimum_ as it travels to the drain connection.
-If that does not solve the problen, it is probably a worn/broken Impeller of the Washing Pump.
Unless you are mechanicly incliend, a service call is probably the way to do. If you need further steps, please reply. Otherwise, after you ahve used the advise, please accept this solution.
Mar 28, 2009 | Dishwashers
Hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Feb 14, 2008 | Dishwashers
Whirlpool 24 in. DU900PCD Built-in Dishwasher Logo
105 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
