Question about Cell Phones
I have an metropcs huawei phone and it is saying DNS not set....so what can i do to fix that?
4 Suggested Answers
  • 1040 Answers
SOURCE: when i try to even
DNS stands for Domain Name Service. Most DNS errors usually indicate lack of a connection to the internet. DNS is used to translate human addresses (for example, www.bhcblog.com) into computer addresses (like 10.64.254.11) ..
This error occurs due to fault in network, Therefore contact your network operator and ask them to solve the problem. Alternatively you can re-install or recreate the internet profile manually with IP address and DNS server address... for this also you should contact your network operator and ask them to provide you the IP and DNS Server address...
Hope this has helped you.. THanks
Posted on Jan 05, 2011
taran_2005
  • 10515 Answers
SOURCE: i have a metropcs huawei
The below mentioned Points should be Considered to Fix this :-
1. The First thing, i have Found with most of the Handsets is that they are LOCKED. Make sure that the cell phone you are using should be Unlocked. In case, it is Locked, Contact the Original Service Provider and get the Code to Unlock or you could Search Different Sites who claim to Offer that ( Note - I never used any Site and i am not aware whether it would be Hit or Miss ).
2. Make sure that there could be a Signal Problem. There are Cases, when you Cell Phone could Read ' Emergency Only ', if there is No / Less Network in that Area. Try to Use it away from that Place. If that is the same problem, then you need to troubleshoot the Cellphone.
3. Have you tried Setting it for Manual Network. In Most of the networks, Automatic Network Search is Set as Default. Change it to manual and Search that. Usually this would work on most cases.
4. Network catching Capability also Depends on the Handset. No two Handsets could have the Same Capability. You could try to Use ' Network Boosters ' which is available with most of the Online Vendors or Local Shops.That could really help the cellphone to Catch Network.
5. If it still shows Message like ' Emergency Calls ', then it could be a Defective Antenna. Take another Set ( Same Model ) and Compare, is that an issue with Both Sets or Your Set. If that is Only with your Handset, you need to send the Cell for repair.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 13, 2011
SOURCE: How to set DNS on
When I get on the Internet it says dns not set, how do I set my dns
Posted on Sep 18, 2011
Huawei com support
load the huawei pc suite to your laptop. sync your phone to your laptop then by using windows office or notepad you can cut and paste the message, or depending on the make of printer you have you can look on playstore for the printer app to install on your phone
Jul 24, 2014 | Huawei Vitria for MetroPCS Cell Phone
How to resart a Huawei MetroPCS M735
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Sep 03, 2012 | Huawei MetroPCS M735
My huawei keeps saying dns not set
go to settings configure the dns 8.8.8.8
May 21, 2012 | Huawei Metropcs M750 M750
My dns isnt set it says. how do i fix it?
The wireless access point isn't passing DNS to your laptop. Go in an manually assign 8.8.8.8 as the DNS setting.
Type ncpa.cpl into the Start menu search box or hit the Windows key + R at the same time and type it in that box. Right click on the wireless connection and select Properties. Go down to TCP/IP and select it. Click Properties. Enter 8.8.8.8 in the Preferred DNS server box and click OK. Click OK on the Wireless Connection Properties box.
Edit- Reboot your laptop with those new settings. I'll check back in about 45 when I get home to see if you are still having problems.
2nd Edit - Type ncpa.cpl into the Start menu search box again to bring up the Network connections screen. Right click on the Wireless connection and select Diagnose. Let me know if that takes care of it.
thanks.
Apr 19, 2011 | Huawei Metropcs M750 M750
How to set DNS on my Huawei m750 to connect to the enternet?
Feb 15, 2011 | Cell Phones
When i try to even access the internet on my touch screen huawei m750 phone it displays dns not set on the screen. how do i fix this problem?
Jan 04, 2011 | Cell Phones
The phone doesnt turn on and when it does it goes black and white on the screen.
hello i e mail you before about my metropcs huawei m318..this metropcs company is totally phone fraud.they have a block on my phone ..here is my phone number 1<562>219-8921 here is my esn#01807188604 this company metropcs hasn't repaired my phone or sent me a replacement phone.my phone has a lcd phone screen technical problem i have a black spot on my phone that blocks my phone from text messages or when my phone was on can't read phone numbers because of black spot on phone..metropcs is not a good cell company its been 4 long months of nothing.my cell is block and off please turn on phone and unblock it.urgent/urgent/r.s.v.p
Apr 23, 2008 | Ericsson Cell Phones
Cell Phones Logo
302 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
