Computer keeps turning itself off - Computers & Internet
  • 1,314 Answers
This is usually due to a heat issue, possibly from accumulated dust inside the machine. Take the side off and, using canned air available in most electronics departments, blow the dust off of the cpu, heatsink, and fans as well as the ventilation areas. Then blow the rest of the dust out as well.
Thanks and please take a moment to rate as fixya. Thank you.
Posted on Jul 09, 2008
The WiFi keeps turning itself on. I turn it off and it turns itself back on ..
Why would you turn it off unless you are using another wifi adapter?
Most computers are set up to start the wifi when restarting the computer as default. If you don't want it on, don't restart the computer. I never restart mine, I just put it to sleep. It is dormant until you click something to make it wake. Nothing is working while asleep or hyberated. Perfectly safe, (but turn off the mouse it may wake with vibration of walking across the room).
Oct 25, 2014 | Computers & Internet
Computer continually reseting
I will need to know what operating system you are using and does all the programs reset itself?
Jan 23, 2014 | HEWLETT-PACKARD HP 4525s ProBook
My computer keeps switching itself off and won't swtich back on again? What can be the problem?
By know you should of fixed the problem .
1. keep the inside cabinet clean.
2.If the unit keeps shutting down by itself after a certain time and it is not dirty inside the cabinet .Also all the intact screens are clean . Check your Personlization settings By right clicking on your screen . then right click Screensaver and then power settings . Then check to make sure all the settings are turned off unless you want the computer to shut down after a certain amount of time
Oct 30, 2012 | LG Computers & Internet
This desktop dell vostro turns itself on and off without the button being pushed. sometimes it makes it to windows, and seems to run just fine, then it goes to shutdown by itself... then turns itself back...
Well in the system Bios or setup there are options where you can have the computer turn itself on automatically at a certain time. However, the fact that yours is turning itself on and off seems to indicate that it is either over heating or it is running into an issue when trying to boot and it keeps recycling the boot process. There is an option that you can set that will turn off automatic restart on boot. Turn off the computer and then turn it on and start hitting F8 repeatedly until you see Safe Mode as an option. Scroll down through the options and you will probably see an option that lets you stop automatic restart on boot, and take it if it is there. This will allow you to actually see the error message that is causing your computer to reboot itself.
Mar 19, 2012 | Dell Vostro 410 Desktop Computer
Computer comes on and is fine for a while then just cuts off,then turn it back on then its fine for a while then cuts back off.
To start with, you should check all your hardware. A loose connection somewhere or a faulty piece of hardware could be the reason, the computer keeps rebooting itself. In case your RAM stick is not fitted properly, or is corrupt, the computer displays an error message on the screen and keeps rebooting itself. The same problem occurs with a hard disk. You can use 'Memtest86' to run a hard drive check.
You may at times come across an error message on your screen, like a system failure error, before rebooting by itself. There is a particular solution to this type of problem. You should first go to the My Computer icon and right click on it. Select properties, and a window will appear on your screen. Click Advanced tab → Start Up and Recovery → Settings. After clicking the settings option, you will have to uncheck the box next to Automatically Restart. Click OK twice. This will prevent the computer from rebooting itself and you can redress the issue.
A different way to tackle the problem of 'computer keeps rebooting itself', would be to restart your computer in the Safe Mode. Allow the computer to boot fully and let your windows operating system load fully. Now, if your computer keeps rebooting itself even in the safe mode, there is a problem either with the operating system or hardware. And if your computer is not rebooting itself in safe mode, the problem is related to certain software.
Over heating is another reason why your computer keeps rebooting itself. Not many people pay attention to this aspect though. The fan responsible for keeping the CPU cool, may be malfunctioning or there could be dirt settled between the fan and CPU. Any one of these could be the reason for your problem. Either clean the fan area, or replace it if necessary. Try providing proper ventilation for your CPU, so that it stays as cool as possible.
You computer could reboot on it's own if you have installed improper drivers. Right click on the 'My Computer' icon, and click on 'Properties' from the menu list which appears. A new window will open. Select the 'Hardware' tab, and click on 'Device Manager'. A list will be displayed on the screen in which you will have to check all categories. Is you see any red or yellow warning icons, make sure you update that particular driver from the internet.
Dec 13, 2010 | Computers & Internet
Pc keeps turning itself off
I would suggest you first disconnect the computer and give it a good cleaning inside. It may just have so much dust inside that it is overheating. Here are detailed instructions on how to do it.
Nov 30, 2009 | Computers & Internet
Logitech Z-5300 Turns off and on by itself
Im not sure if this will help u but check ur Remote's power botton.
Maybe its stuck?
It happened to me before... Was wondering y it turns itself on/off and found out later that the power botton on remote is stuck.
U should hear the clicking sound everytime u turn it on or off.
Otherwise... something else is wrong with the power switch on ur remote.
Sep 19, 2009 | Logitech Z-5300 Computer Speakers
Computer keeps restarting itself after a few mintues of turning o
I would try to got to safe mode with command prompt and at the dos prompt I would type in chkdsk c:
Jan 16, 2009 | HP Pavilion dv1000 Notebook
Computer turns itself on
if you can get into bios check and see if there is any type of alarm or auto on set up. If not or if its not that big of a deal just use the switch on the back of the power supply at night. Make sure you shut down your computer before switching this. It will definately keep the computer from turning on by itself.
Dec 30, 2008 | Dell Inspiron E1505 Notebook
Phone keeps reseting itself
my phone keeps turning off and on when i disconnected my phone from the computer it said reset but now it keeps on turning on and takes me to the munu and then 10seconds it goes off so please help me figure it out and do something
Jul 10, 2008 | RIM BlackBerry Pearl 8100
Computers & Internet Logo
207 people viewed this question
David Payne
David Payne
