Question about Xerox Phaser 6110MFP All-In-One Laser Printer
Did not get a manual with this printer and do not know how to fix a paper jam
I found a manual for both versions of this printer (with scanner and without) on the support.xerox site.
Posted on Jan 28, 2011
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
Paper jam inside machine
You need to open your printer. Some printers even have back opening panel for fixing paper jams. Since you didn't say which printer are you referring to, try searching here for user manual and see if it will help: Download Free Manuals
Jan 03, 2016 | Office Equipment & Supplies
Am getng an eror 3 which is regarding paper jam in printer canon140 mp but der is no paper jam in printer.. need help...
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Oct 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
IBM 1332 printer error #241 Paper jam
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
  • Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Oct 04, 2010 | IBM Infoprint 1332 Laser Printer
Kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
Jul 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam.
try this, its probably a small part of jammed paper inside or then theres a problem with the paper pickup, try cleaning it.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Oct 26, 2008 | Lexmark X83 All-In-One InkJet Printer
Savin 2513 Jam
Many printers have a paper jam alert.But you need to remove the jam the correct way. You can't just pull the paper from the machine. If you have the manual--look up the proper procedure to un jam the paper. The machine can detect if the paper is stuck and it will not know it is fixed if the proper method isn't used. The system has a mechanism that loosens the rollers to allow the paper to be removed without damaging the wheels.
Oct 12, 2008 | Office Equipment & Supplies
Dell photo printer 942 all in one paper jam
Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. Up-grading the printer firmware could also fix this kind of issue, however I would appreciate if you try the steps below before you up-grade the printer firmware.
To fix the paper Jam errors please try the following steps:
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set does not exceed the required limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
If the above mentioned steps do not fix the issue please up-grade the printer firmware form the Support.dell.com web site. However make sure that you do not turn off either your printer or computer when you are downloading and installing the printer firmware.
Alternately you can also try to download the and install the printer drives form the support site if the paper jam message is being displayed on the computer’s screen but not on the printer’s LCD screen.
Should you require any further assistance regarding the printer or even any other computer related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Jan 31, 2008 | Dell 942 All-In-One InkJet Printer
Xerox Phaser 6110MFP All-In-One Laser Printer Logo
57 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
