Question about Numark CD Mix2
One of the trays on my CD2 will not open. There is a cd still in there. The other tray is working fine. How do I get the tray to eject?
  • Numark Master
  • 5,603 Answers
The safe way is to remove the cover. SOMETIMES the problem is a little rubber belt that drives the tray carriage loses traction. To protect the disk, remove the cover and investigate the problem and manually remove the disk.
Posted on Jan 02, 2011
Cd tray doesn't eject
The tray could be binding or there could be mechanical failure in the mechanism.
Jan 14, 2015 | American Audio Ck-1000 Cd/mixer Combo...
Numark cdn450 has tray error message in left well
For all kind of brands cd or dvd players There is in every cd or dvd tray in the front bottom or under the tray so crazy you can not think an microswitch necessary that will be by mechanic close of the tray detect if the tray is closed and give a timed signal (close or open) to focus laser for reading of table of contents if the belt is bad it can take to long by a slipping tray drivebelt for the detection , or the microswitch or brass plate contacts are have a little corrosion on it or even it can be broken by a missing timing.
Dec 23, 2013 | Numark Industries Numark CDN450 Rack Mount...
I have a Gemini CFX-50 dual cd player. The left tray is not reading the cd whenever I put it in. I am getting a message "no disk". the right tray works fine. What could be the problem? Please help!
If the motor is spinning the disc, then your problem is with the laser. It either needs to be cleaned or replaced. Cleaning can be done with a regular laser lens cleaning disc, available at any store that sells electronics. A replacement lens assembly can be picked up at any store that specializes in electronics.
Oct 21, 2013 | Gemini Sound Products Gemini CFX 50 Dual...
The disc tray does not open in my RSQ NK2000U
I have the same problem wtih a RSQ500. I removed the cover and unscrew the top of the disk drive to remove the disk that was inside. I going to try to put the cover back and see if it works
Mar 21, 2013 | RSQ NK 2000U
When i turn the cd player on its reading like a cd is in it but it not
reverse the pin of mains supply and try ,and open close cd tray switch,clean cd tray with smooth brush
Sep 03, 2012 | Stanton C314 Tabletop CD and Mp3 Player
Numark KMX02 left hand CD will not eject
Usual cause is a little rubber belt either deteriorated or is slipping that drives the carriage to do the eject. Open unit and recover the CD and the drive belt will be obvious...
Apr 14, 2011 | Numark Industries Numark KMX02 Dual Deck...
One tray on the right side of my cd player will not open Gemini CDM 3600
Typical problem is a little rubber belt that drives the tray carriage from a motor... it slips or deteriorates.
Jan 19, 2011 | Gemini Sound Products Gemini CDM 3600
Hi. How do I fix a CD deck that wont open if I press eject? The deck refused to open with a CD inside. The deck wont play the CD if I press play and wont eject if I press eject. please help. Thanx TC
To retrieve the CD safely, the safest way is to open the unit. A common problem is that a tiny belt from a motor that drives the eject deteriorates and slips so there isn't sufficient drive to move the mechanism. The unit is probably in a mode expecting to eject and has commanded the motor but it doesn't complete... Do as I say and open the unit to do the retrieval. Then get unit serviced.
Dec 04, 2010 | Gemini Sound Products Gemini CDM-3700G /...
Numark CD Mix2 Logo
236 people viewed this question
Top Numark Music Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
