Question about Ovens
This oven has a motor driven electric door lock located immediately behind the control panel. When I attempted to put it in the clean mode, the 4 hour timer came on as it should, the lock door icon started flashing, but the motor never started nor made a sound, nor will the door lock. Eventually, when the door doesn't lock, the clean mode goes off. I have tried resetting everything several times both on the control panel and shutting off the power to no avail. The motor number is WB26K5030. I am wondering if I should order a new motor or if this might be a control panel problem.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you can remove the motor, put 120 volts on it, if it does not work, their is your problem.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Testimonial: "Thank you. I will try that. Very Rapid Response!"
What can I do for F5-E1 situation
Check this article as the cause could be the control board, the door lock mechanism or the Membrane Keypad!
Whirlpool Oven Common Problems and Causes
Jan 08, 2015 | Ovens
Oven is stuck in lock mode
Hi Lora, this is AP!
Based on the description of the Frigidaire electric range provided it appears the door lock feature has been activated. In order to cancel the Oven Lockout feature, press clear off and hold for 3 seconds. The control will unlock the oven door and resume normal operation.
This door lock feature is activated by pressing clear off and holding for 3 seconds. "Loc" will appear in the display, the "Door Locked" indicator light will flash and the motor driven door lock will begin to close automatically. Allow about 15 seconds for the oven door to lock. Once the oven door is locked, the current time of day will appear in the display. If any control pad is pressed with the oven lockout feature active, "Loc" will appear in the display until the control pad is released.
This information is also located in the owner's manual should you like to view it again, you may retrieve a manual using your model# and the following link http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/.
I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Mar 17, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
Got error code F9 while oven cleaning in process. What does this mean?
An F9 error code on a General Electric (GE) oven indicates that the oven's electronic control system has detected a problem with the automatic door lock.
The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode.
The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
9 out of 10 times the lock switch has failed.
STEP # 1 - Disconnect power to the oven!!
  • Step 2 Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
  • Step 3 Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
  • Step 4 Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation2_bing.gif. Repair wires as needed if defects are present.
  • Step 5 Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
  • Step 6 Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
  • Step 7 Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
  • Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Apr 01, 2010 | GE Profile JTP56 Electric Double Oven
    My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
    F90 Maximum oven door unlock time exceeded.
    F91 Maximum oven door unlock attempts exceeded.
    F92 Maximum oven door open time exceeded.
    F93 Maximum oven door lock time exceeded.
    F94 Maximum oven door lock attempts exceeded.
    1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
    2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
    3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
    4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
    5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
    6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
    7. If all situations above do not solve problem, replace EOC.
    F90 is a door lock code, Try this...
    unplug the range.
    wait 1 minute.
    turn the range back on,
    then while holding in on the oven door.
    start another self clean.
    wait 2 minutes.
    then cancel the self clean.
    do not release the door until the door lock light goes out.
    Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    How to start oven in PROPANE STOVE
    Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
    Component Test Procedure Results
    Electronic
    range control
    F1−1 –Upper Oven >650°F with door unlocked.............................
    F1−2 –Lower Oven >650°F with door unlocked.............................
    F1−3 –Upper Oven >950°F with door locked.................................
    F1−4 –Lower Oven >950°F with door locked.................................
    F1−7 –Membrane switch is not responding ...................................
    F3−1 –Upper sensor is shorted at (< 100 ω) or
    open at (>5 K ω) ...............................................................
    F3−2 –Lower sensor is shorted at (< 100 ω) or
    Check actual upper oven temperature,
    if > 650°F check sensor.
    Check actual lower oven temperature,
    if > 950°F check sensor.
    Check membrane switch for connection or damage.
    Check upper sensor, harness, and connections
    Engineering
    Test Mode
    Press BAKE pad.
    Enter 100°F using the number pads.
    Immediately push and hold BAKE pad for appropriate oven
    approximately 3 seconds.
    This mode can also be entered by pressing the hidden pad
    for 3 second located to the left of the lower oven light pad.
    Used to view the actual oven temperature for both ovens at all
    times, even when an oven function is active.
    This mode will also display the current fault code for 5
    seconds in the time digits.
    Fault codes
    accessed
    through
    Engineering
    Test Mode
    F0−0 –No fault .................................................................
    F1−5 –Upper hardware failure within control ....................
    F1−6 –Lower hardware failure within control.....................
    F1−8 –Shorted key in membrane switch ..........................
    F1−9 –Internal communication errors within control .........
    F1−A –Upper latch switches ............................................
    F1−B –Lower latch switches.............................................
    F1−C –Upper door switch.................................................
    F1−D –Lower door switch.................................................
    F1−E –Sensor input not calibrated ...................................
    F1−H –EEPROM error .....................................................
    F1−L –Temp in ovens are the same for long period .........
    F1−N –Internal voltage on control not working .................
    F9−1 –Upper lock switch is not correct.............................
    F9−2 –Upper unlock switch is not correct.........................
    F9−3 –Control does not see upper door lock....................
    F9−4 –Lower lock switch is not correct.............................
    F9−5 –Lower unlock switch is not correct.........................
    F9−6 – Control does not see lower door lock ...................
    EE –Control cannot read E-PROM. Unit will shut down.
    Default from factory
    Replace control
    Replace control
    Check membrane connection
    Replace control
    Check latch wire harness
    Check lock wire harness
    Verify sensor is operating properly
    Replace control
    Replace control
    Check lock wire harness, and lock switch
    Disconnect power for 60 seconds. If EE reappears, replace ERC
    Test Mode This mode must be activated within the first 5 minutes of
    power up.
    Press BROIL and CANCEL pad for approximately 3 seconds.
    If oven temperature is greater than 400°F, the Test Mode
    cannot be activated or will abort if active.
    Press and hold individual pads for 4 seconds to activate.
    Display will have dashes in all segments to indicate the mode is
    active.
    Upper Bake: Energizes upper bake element
    Lower Bake: Energizes lower bake element
    Upper Broil: Energizes upper broil element
    Convection Bake: Energizes convection fan
    Upper Oven Light: Energizes upper oven light
    Lower Oven Light: Energizes lower oven light
    Upper Clean: Energizes upper motorized door lock
    Lower Clean: Energizes lower motorized door lock
    Stop Time: Energizes Beeper
    Cook Time: Displays error codes
    Timer 1: Energizes ROM version
    Timer 2: Energizes EEPROM version
    Keep Warm: Cooling Fan
    Clock: All display segments light
    If functions do not perform as specified, replace ERC
    Oven
    temperature
    adjustment
    Push BAKE pad.
    Enter 550°F using the number pads.
    To decrease or increase oven temperature. Push AUTO SET
    pad until negative or positive numbers appear. Oven can be
    adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
    To avoid over adjusting oven move temperature -5° each time.
    Push OVEN CANCEL button.
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
    Flashing locking door light
    Re : Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back.
    That cames from an old thread and is a generic explanation of how it works. Here original reference
    GE Profile Electric.
    There is no electrical cylinder because the solution was referring to a different model and a different problem. In case linked above the door was locked, in your case door is clicking continuously, showing that there is a contact or a faulty door lock motor control.
    If I was doing the repair I would start reading voltages on lock motor motor harness with motor wiring cut, this will tell you if contact is inside lock motor assembly or on control. The test can be done either from control side (easier access) or from lock motor, after disconnecting the harness.
    If the control actuator keeps turning on and off , then replace the box in there, otherwise work on wiring harness and on lock motor.
    This is not an easier repair, and tests with live power in there may be riskyd if you have not enough experience. If you are a beginner just inspect wiring with power off first, then replace control, and if that does not fix the problem replace wiring harness.
    Here parts that must be tested, and relative diagrams:
    LOCK MOTOR WIRE HARNESS (LCK MTR HARN) connects to part 999 on diagram.
    LIMIT SWITCH(LOCK)
    Part 158 on diagram.
    If problem is not in control or wiring harness, then check if there is a contact inside door lock assembly or on LOCK MOTOR connectors. If two connectors on picture below are making contact, that is the problem:
    As a matter of principle , do not forget to leave feedback, or you may end up rewarding the person that copied and pasted a solution for the wrong problem.
    Thanks, and thanks for asking Fixya.
    Ginko.
    Sonce the proble
    May 16, 2009 | GE Profile JKP56 Electric Double Oven
    GE: E Profile Single Electric Oven Model: JSP40W0WJWW
    First press and hold the cancel/off button for 10 seconds.
    If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
    The 2 thermal switches are located on top of the oven behind the control panel.
    Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
    GE Double Oven doors locked and circuit not responding
    Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
    Good luck,,,,,,,,,,,,,,,
    Jan 02, 2009 | GE Profile JTP56 Electric Double Oven
    Frigidaire 318047401 electric oven
    Door lock motor has probably failed.....Self clean on many
    ovens can be a self destruct mode. Door latch motors, sensor
    probes and even the electronic controls can be destroyed by
    this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
    Jun 02, 2008 | Ovens
    Ovens Logo
    83 people viewed this question
    Top Ovens Experts
    ashburton
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
