I was given a Centrios 13 in 1 Card Reader as a gift a couple of years ago. I have successfully read SD cards on it. However, I can't seem to insert my XD card into the designated space. Any suggestions?
sainisonu
  • 156 Answers
SOURCE: memory stick / card slot not reading
Right click on my computer,click on properties,Click on Hardware Tab,Click on Device Manager tab.Here u can find ur multimedia reader.If it is disabled it shows red cross on it.Or if it is not installed it shows yellow exclamatory sign on it.
Regards
Sandeep
Posted on Oct 25, 2007
nickuk23
  • 34 Answers
SOURCE: SD Card Reader won't work?
have you tried other sd cards before or is this the first time?
if you have and its just this time it hasent make sure its working in your camera or mp3 player or where ever it came from :-)
if it works have a look in your device manager to make sure there are no problems with the drivers.
1 start
2 control pannel
3 system
4 then the hardware tab and click the device manager.
if there are anyproblems there is useually a little symbol next to the device just double click on it and have a look for the error code.
if all else fails try reinstaling the driver for your card reader or find an updated drivr download.
hope this helps
Posted on Dec 07, 2007
coleslaw424
  • 43 Answers
SOURCE: sd card
First you need to see if the computer reconizes the reader, to do this you double click on the computer icon on your desktop, then look to see if there are any drives other than your hard drive and cd roms. If the computer does not see the reader then you may need to download drivers. As to how to get the drivers it depends on your setup if the reader was installed in the computer when you bought it then you will want to go to the computer manfactuer website, if you bought the reader seperatly then you should have recived a disk with it if not go to the website of the card reader manfactuer.
Hope this helps.
Carl
Posted on Feb 07, 2008
  • 17 Answers
SOURCE: tech-com 25-in-1 card reader in vista
the reason its failing is because vista doesn't play well with certain SD cards.
more than likely your SD card does not support 1.8 volts. (Typically, most SD cards use 3.3 volts.) and your comp might be running a 1.8 volt SD host controller.
also this occurs because of a timing issue with the SD host controller. (might be why it works sometimes)
Luckily Microsoft has SILENTLY (typical) released a fix for this problem
you need hot fix 936825...... download it, install it and reboot.
I think this is the link for the page where the fix is (requires validation to make sure you actually own vista)
http://www.microsoft.com/downloads/details.aspx?familyid=E42FC131-6A76-4B27-934A-FB19DD323DAB&displaylang=en
If not, go here and search for 936825
http://windowsupdate.microsoft.com
give this a shot and see what happens first. you could still have it set as an unknown device for some reason (windows sucks)
if the fix doesn't work, kick me an email
good luck! let me know how it turns out,
Posted on May 07, 2008
SOURCE: memory card not initialized
Card not Initialized
Posted on Apr 16, 2009
Why wont my computer read my SD card? i have a Samsung TL210 double view hd camera. when i put my 8gig SD card in my computer nothing happens at all i have a vista computer ok. i am 13 years old so make...
If the 8Gb SD card works on your HD camera, then the problem is with your built in memory card of your computer. Most of the built in memory cards of the computer only supports up to 2Gb.
You can actually isolate it by trying to test an SD card lower than 8Gb to your computer.
Solution for this is to use external USB SD reader that supports high capacity SD card (SDHC) or contact the manufacturer of your computer and ask for firmware updates for the memory card reader. Hope this is clear and would help you.
Jul 01, 2011 | SanDisk 8GB microSD High Capacity...
What do i buy so i can attach my digi power dp-fcr20/ mini sd/ms duo card reader/writter so i can attach my mini sd to it and sorry if hard to understand
If the card-reader states it's for a mini-sd card, then you should just be able to insert the mini-sd card into one of the slots. However, some card readers double-up on slots by making it so more than one card-type can be inserted into the same slot. See if the mini-sd card can be put into one of the slots successfully. Tip: Read your manual before doing so, so you don't get card stuck in wrong slot.
Mar 31, 2011 | Computers & Internet
Put new SD card in (Micro Center brand) can only read card when I plug camera into computer cannot read card when I plug card into computer. Card slot on computer works on my Nikon card.
It is possible that the card may be corrupt or damaged, you could try to get a Canon SD card and try that , I'm guessing that the camera came with a Canon SD card when it was new?. The Micro Center SD cards come with a 3 year limited warranty so try contacting them, personally I use Kingston SD cards.
Apr 04, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
Cnt download music doesnt show on computer
Is the problem that you have music in the HCSD and can not get it into your computer because the computer does not see the SD card?
If yes, many older (and not that old) computers will recognize the HC vesrions of the SD cards. My computer that I purchased about a year ago has no issue with them, another computer I work on at church, bought 3 years ago, will not recognize it. I think it has more to do with the card reader than the computer itseld though.
Upgrading the card reader may solve your problem. determine the manufacturer of the card reader in your PC and go to thier website to see if updated drivers or firmware are available.
Peace,
Mar 07, 2010 | PNY 4GB Secure Digital High Capacity...
My SD card reader on my Sony Vaio will not read the card...it seems to know its in the slot, but won't read any data and says 'insert the SD card' if I go to computer and try to read it. Any thoughts?
Take a can of air and blow some into the slot to make sure dust or dirt isn't getting the way of that reader trying to read the sd cards.
If you still get the same message try another SD card in that reader or try to see if another computer will read your SD card, if another computer will read the SD card and the slot still won't recognize the sd cards properly, then you know at that point the reader is bad. If the reader is bad, thats integrated into the motherboard so the motherboard would need to be replaced.
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
My 9 in 1 card reader is not working
please check the SD Card whether it is orginal or not.if everything is fine with SD card, the problem may be with your reading gead of the device.please see whether any virus is affected or not.if this is because of some virus , you need to do formatting
Aug 08, 2009 | Computers & Internet
I have a 4gb sandisk micro sdhc with adapter and the computer freezes when i have it in the sd drive.I have a hp pavilion a1 a1203w. Is there anything i can do?? Please Help
I had a similar problem not long ago. The SD and SDHC standards are different. SD only goes up to 2GB, and SDHC (high capacity) goes higher than 2GB. THe problem is that SD card readers aren't capable of reading SDHC cards, even though the card will physically fit into the card reader slot. When you insert an SDHC card into an SD card reader, the reader attempts to read the format, and locks up the OS while trying. You'll need to get an SDHC card reader and use it separately like through a USB port or something.
May 13, 2009 | Computers & Internet
Acer aspire one won't see my olympus SD MASD-1 micro SD attachmen
You may need the card reader drivers installed. What is the exact model (110, 150, D150?) and operating system of your laptop?
Drivers can be found at the following link given the model of laptop, I can help you find it further if you provide the requested info above.
http://support.acer-euro.com/drivers/downloads.html
Mar 12, 2009 | Acer Aspire 4315 Notebook
SONY DCS T1 FORMAT ERROR C:13:01
Hi.. I think you have solved the problem yourself... replace the adapter with a memory stick... You have eliminated the micro sd card as bad... now try a new known good memory stick..
Thanks
jim
Feb 18, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Wii sd card reader
i think that you must format the card. try that first and if it still doesn't work, maybe try a lower capacity card (though capacity shouldn't be the issue)
hopefully that helps
Jan 02, 2008 | Nintendo Wii Console
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
