Question about Kenmore Dishwashers
There is no water getting to the diswasher. It goes throught the cycle but does not have water in the machine. the water supply is good.
  • Steve Shaffer
    Steve Shaffer Jan 01, 2011
    Hi Kevin and thanks for the quick response. The two terminals of the water inlet valve should be checked for 120 volts??
  • Kenmore Master
  • 1,902 Answers
Hello & Welcome to FixYa
When the water comes however, won't go inside the unit then it indicates that the problem is either with a clogged/blocked inlet valve or the water inlet valve itself has gone bad and needs replacement. You can also test two terminals of the water inlet valve before replacing it. Please get back to me if you have any other questions.
Kevin
Posted on Jan 01, 2011
  • Kevin White
    Kevin White Jan 01, 2011
    Yes if it reads infinity replace them.
I have a Bosch diswasher model SGS44E12EU it is not filling up with water when turned on and so the cycle does not work.
hello, check the pump first make sure theres no water left in the machine if ok then check water supply to the machine if this ok then the cause could be the water inlet values on the machine make sure they are not blocked hope it helps
regards
shaun
Mar 26, 2011 | Bosch Dishwashers
Water is not pumping into the diswasher
Check that your supply faucet is open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is getting to the valve, the timer might be faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working).
Mar 13, 2011 | Dishwashers
I have Frigidaire FDB956RBC1 diswasher. I have to turn off the water to fix the faucet. When I turned the water back on, water did not go to the diswasher when I used it. The diswasher runs normal except...
FRIDG... EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | Frigidaire FDB956RB Built-in Dishwasher
It shows an F 20 fault after it goes to the wash cycle. I have taken the hoses offf and cleaned the screens. It is getting plenty of water throught the fill valve but still stops with an F 20 fault.
Hi
Thanks for using FixYa. Error F20 indicates no water is entering in machine and/or the pressure switch trip was not detected. To resolve this issue check the water supply has been turned on, then check the water inlet valve for any clogs and clean it. If there is water in the unit then check the drain pump and also verify that the pressure switch is working fine. If the water inlet valve has gone bad then it should be replaced. Also check the wire harness connections to the water inlet valve and pressure switch. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 | Dishwashers
Washing machine isn't spinning to drain water
suggest that the drive belt is worn and slipping under exess load solution replace belt regards billnkaym
Apr 02, 2009 | Whirlpool LSQ8543J
DISWASHER hdw100wht
You could if you wanted a hot wash. You cannot dry without cold water. The dryer cycle requires cold water to draw moisture out of the clothes.
You can create a custom program that has no dry cycle. I usually do the laundry this way and hang dry, however I only have cold water hooked up.
You could get cold from the cold tap by installing a few outdoor hose quick connect parts to the tap if your faucet ends in a screw fitting. You may also need screw on expander for this to work. Go to you local hardware store and tell them you want to get the outdoor hose quick connect parts and an expander to fit on your household tap. Buy metal parts NOT cheapo plastic.
Mar 23, 2009 | Haier HWD1000
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
