Question about Yamaha 1,000 Watt Portable Generator #EF1000ISC
I have a Yahama 1000, it won't stay running unless the choke is pulled out all the way, what can my problem be?
I have the same problem, did you find the solution please?
Posted on Feb 11, 2011
Acts like the choke is stuck closed it won't stay started and runs ruff until engine warms up then its fine. What do i do?
Well the choke has an electric part that heats up and makes the choke open in a few minutes. As soon as the engine starts the choke should open about 25 percent by way of a vac pull-off.
You can take the air cleaner off and watch the choke while someone starts the engine cold. If the choke does not open after it starts, check the choke pull-off. You can also open the choke with a screwdriver to see if the engine clears up.
Jan 29, 2013 | 1987 Chevrolet Caprice
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
I have a Ryobi 780r that won't run unless it is on choke. The moment I remove the switch from choke to run it shuts off.
This means you have an air leak somewhere adding more air than fuel with the choke off. With the choke on it blocks off the fresh air coming in and mixes with the maverick air from the air leak. You need to find the leak and fix it or you may damage the unit
Jan 10, 2013 | Ryobi Garden
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
I have a 1984 Maxim XS 400 L that won't stay running unless choke is on
Hi, Dmg24jeff and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Only runs when choked
Bike won Run without Choke
Yamaha XS400 1977 1982 Factory Service Repair Manual PDF Download Manuals... $10
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xs-owners-manuals
May 23, 2012 | 1984 Yamaha XS 400 L Maxim
2007 Honda Shadow VT750C only idles with the choke on
Hi, S and the usual suspects are:
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Help Bike will only run on full choke
Starts but won stay running unless with choke Discussion
Honda VT750C2 Shadow Spirit Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Jan 23, 2012 | 2007 Honda VT 750 Shadow
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
2002 Honda VT 1100 C2 Shadow Sabre will not idle without the choke being on
Hi, Esw2035 and the usual suspects are:
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Need Help Bike won run choke in
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Apr 21, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
Yamaha 1,000 Watt Portable Generator #EF1000ISC Logo
437 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
