Question about Apple Logitech Inc MM50 Portable Speakers iPod 970173-0403 Computer Speakers
My PC speakers only work at very low volume setting, then it's staticky and the sound is terrible. I have checked all the connections. They weren't super expensive $22 at Walmart, but are less than a year old so wonder what's up? Aloha, Mikie Happy New Year and please check out my blog: www.GetOffYourButts.com
  • 68 Answers
Did you use device manager on your PC to see if your device need to be updated to its lastest version
Posted on Jun 28, 2013
Speakers, no sound
Since they were working, check the basics first.
  1. Check the speakers on another device. Mp3 player will work fine.
  2. check the sound card on your computer (use a set of headphones or another speaker set).
  3. If you find they weren't plugged in, powered on, etc. resolve that. Usually the power plugs are black, and only fit in one spot. The audio cable to plug into the computer is similar to a headphones jack (3.5mm). On most computers the audio output (speakers) port is colored green.
  4. If none of these get you fixed, go into the control panel and click the sounds icon. From there you can view your volume levels (is the sound muted?), view your playback device (it might have a hardware problem, or be disabled), and test the settings.
  5. If you are still stuck after this please also post your version of windows, and the make/model of your computer. If you know it, the type of audio device you are using would also be helpful.
Thanks for asking, and Good Luck!
Dec 18, 2011 | JBL CREATURE II Computer Speakers
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
My speakers sound is terrible now. I changed the
Forst thing is to put a known signal into the speakers, say from a CD recorder to isolate a possible mixer or other source being marginal.
If the sound is still bad, verify that your volume settings are reasonable.
DO NOT crank the gain on these speakers full and then throttle the signal to them as that cause poor signal-to-noise ratio.
If you have driven these speakers very hard (these are only INTENDED for lower level monitoring within the engineer's booth), you MAY have damaged the speakers. It htat case, repair will be necessary.
Try to determine if the lows or highs or both are bad sounding.
Jun 17, 2010 | Mackie MR5 MR5 Reference Monitor
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
Why would my car stereo sound staticky when i give it volume'',it was not like that earlier
first adjust the fade and balance, checking each speaker for this issue. if they all continue to cause static when turning up the volume, then it is either the connections are crimped poorly, speaker connections are not secure at speaker or just a faulty volume control knob
Feb 23, 2010 | JVC Car Audio & Video
No sound!!!
Check your computer sound volume. Make sure it is not muted or the volume is set low. Try the speaker into a music player like ipod or mp3 player that will support the speaker jack. See if it works..
Nov 29, 2009 | Dell WL6000 Computer Speakers
Sound is low
try to see if the wave volume is on and maximum on the volume panel ( double click on vol icon on tray system (right low) ) ...also see if your speakers are plugged into the proper place ...and are not in the auxiliary out or something like this ...they should be plugged into the green middle out ...if they are simple stereo 3,2 jack ...so ..if the problem its still on ..its probably the sound card...(actually the pre-amplifier on it ..)
Aug 03, 2009 | Dell Dimension 3000 PC Desktop
My speaker sound terrible its like my speaker is grounded
Check your sounds software first, sometimes the software problem can give terrible output, check in the input plug ,the wrong plug can give terrible sound quality if that too doesn
't work see your setting for sounds.
Jun 12, 2009 | Computers & Internet
JBL Creature Speakers have very low volume
I had the same problem. Then I read about the volume controls on the right speaker. They are silver buttons for me on the front bottom left and right of the speaker. Now they play really loud!
May 30, 2009 | JBL CREATURE II Computer Speakers
103 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
