Question about Viking 37 in. VGSU161 Gas Cooktop
I have a Viking VGSU161-6BSS cooktop and need to replace a dead igniter. Please show me how to take it out and replace it.
SOURCE: Viking Gas Cooktop - Ignition sparks continuously when in 'on' position
This is likely caused by either a dirty ignition electrode, a cracked ignition electrode, or a bad spark re-ignition module.
Clean and inspect the six electrodes for cracks, If that doesn't solve it order a new
Ignition module from an internet appliance dealer that carries Viking parts like Appliance Zone.
If you replace the Ignition module yourself, make sure to turn off the circuit breaker to the range/cooktop before you work on it. Also, make a drawing of where the different color leads are plugged into the ignition module before you unplug the wires and plug them into the new re-ignitor. If the unit is under one year, this should be covered under the warranty.
Viking had a recall a few years back on their ignitor modules.
Posted on Oct 27, 2008
Kgt1962
  • 59 Answers
SOURCE: Only 1 of 5 burners is working on my Viking electric cooktop
By only 1 burner working, I take you mean only 1 ignites, then it sounds as though you have an issue with the spark module being defective. There is usually an access panel on the bottom of the unit, although not on all of them. Remember to disconnect from the electric.
Posted on Mar 05, 2009
SOURCE: Viking pro 6 burner cooktop igniter won't stop
Do not attempt if your stovetop is hot, you will get burned!!
This is an easy fix, the problem is your burners aren't lined up properly. Remove the iron grates (what your pots rest on) and the burner cap (the round black top on the burner) and finally the burner base (the round golden colored piece resting on the stainless stovetop). If you flip the base over you will see that it is keyed, meaning there is a grove that fits the indentation on the stove top. When you replace the base make sure to line the grove up with the indentation. If it's not flush with the stove top, slowly twist the round burner base until it falls into place. That's it!
Posted on Aug 13, 2009
  • 1015 Answers
SOURCE: viking gas cooktop vgsu161-6b sparks continuously.
The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry though no permanent damage has been done. Leave it unplugged from the electrical outlet for a day or two until the liquid dries out. You can manually light the burners with matches or a BBQ lighter in the meantime. If you want to try and speed up the drying process you can use a hair dryer.
Posted on Oct 20, 2009
  • 491 Answers
SOURCE: 11 year old Viking VGSU161-6BSS with intermittent gas smell.
STOP USING COOKTOP AND TURN OFF GAS AND GET SOMEONE AUTHORIZED IN AS SOON AS POSIBLE .
Posted on Oct 22, 2009
Removing spark module viking gas cooktop
Usually any control knob will activate all four igniters it's usually a faulty pressure switch rather than the igniter pack module.
Apr 01, 2014 | Viking 37 in. VGSU161 Gas Cooktop
HAVE A VIKING MODEL NUMBER VGRT360 THEE IGNITER ARE STILL TRYING TO LIGHT AFTER BURNER IS LIT.
Hi ghughes7,
Moisture or water is shorting out your ignitors. Please follow my below Tip on repairing the problem:
GAS COOKTOP CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 05, 2011 | Viking VGRT360-6B 36 in. Gas Cooktop
I hav a Viking professional. Only one burner ignites.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Mar 18, 2010 | Viking 42 in. Professional Series...
Viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
My VIKING 31" VGSU 101 GAS COOKTOP. All 4 burners can't ignite .If I light it will work
I have the exact same problem, same model. Read the instructions on this website for replacing the ignitors...looks complicated, also generic to all Viking cooktops. Let's see what we response we get.
Oct 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking 30" gas professional series cooktop sparking problem
And before that Most likely one of the ignition switches (they are under knobs) got shorted possibly due to spilled liquid or a cleaning stuff sprayed on. In that case it should stop sparking after a switch drys. Still no go replace the spark control unit.
Thanks
Kindly rate the answer
Kevin
Jul 06, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Dec 25, 2008 | Viking 31 in. DECU165 Electric Cooktop
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Nov 25, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Jun 03, 2008 | Cooktops
Viking 37 in. VGSU161 Gas Cooktop Logo
1,098 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Ed Mac
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
