Question about Toshiba Satellite P105-S6104 Notebook
I only have 3 choices of resolution 1400X900 the highest and want to use 1080p monitor
  • 4,340 Answers
Download drivers from the manufacturer of the monitor.
Posted on Jan 01, 2011
Help to adjust full screen on the monitor
Hi, this depends on your operating system. Most likely your resolution settings are off, or a monitor setting is not correct. If you are in Windows, go to control panel -> appearance -> display settings -> resolution. Make sure you choose the highest resolution, for a 1080p monitor it should be "1920 x 1080".
If you are already on the highest resolution in the control panel settings, try to get into the settings of the monitor or resetting it, if you provide the model number, I can help you with this.
Jan 11, 2016 | Computers & Internet
I have asus vw192t 19"
Resolution capabilities are a complicated blend of the abilities of your graphics card and the abilities of your screen. You will not always get a 1:1 match. You can improve your chances by installing the "monitor information" file that is usually supplied on a CD that comes with the monitor. Also, updating the drivers for your graphics card (see the manufacturer's web site) might help.
Mar 23, 2011 | ASUS VW192T Monitor
19" monitor problem
Try 1440x900.
Some LCDs don't like going off their supported resolutions.
Dec 09, 2009 | Acer X173WB Monitor
How do I connect the tv to a satillite receiver?
You have multiple options here depending on the type of interconnect cables you currently physically have or are willing to purchase.
Below is a web site with a review of your monitor.
http://us.sanyo.com/LCD-Televisions/720p-31-5-HDTV
The best way is for you to have a HDMI cable. This carries your High Definition Video and digital audio from your Satelite Reciever all in one. The satelite box will also know that your monitor is only able to display the lower 720P resolution than the current 1080P resolution and will automaticly display images correctly.
HDMI is the highest and best way to connect your satelite box to your monitor.
Component - three wire cable 'Red, Green & Blue' is then the next best - note you will still need to have a stereo Audio cable also Red and White dual cable to connect also. This connection doesn't communicate with your monitor and you will have some set up to do on the mointor itself to display the resolution you would like. Between 720P, 'Highest resolution' , 720i ''next highest resolution' then 480p ' next in line' and then worse case 480i 'lowest resolution'.
If you don't have a HDMI cable - and go to by one. Don't go and buy the most expensive. It is best to keep the cable short as possible. HDMI doesn't effectly travel over long cables more than 8'. You will get color shifts in your images. Monstor cable is very expensive and not needed. Anything your local Wallmart and or Target have will be fine under 8 feet.
Blessings,
A/V Media Guy
Nov 21, 2009 | Sanyo DP32648 32 in. LCD TV
Using HDMI : PC - TV picture isn't clear?
Check the resolution you have that port (monitor) set to. Most likely you have it set at a resolution that the TV doesn't like, or perhaps it is set at its lowest possible resolution. Just make sure it is set at whatever the highest your TV handles, 1920x1080, 1280x720, etc.
Nov 15, 2009 | Philips TV Tuner Video Capture PCI Card -...
The resolution comes and goes...
For that when you power up the computer press F8 key then enter in safe mode.
Then uninstall graphic driver then start it in normal mode then install graphic driver again then it wroks fine.
Let me know if you need more assistance.
Thanks.
Oct 05, 2009 | Acer X193W LCD Monitor
Pictures and icons look squatty How do I make them look normal?
change your resolution. depending on whether its a widescreen or not, this can make pictures look squatty. if its widescreen, generally 1400x900 is a good resolution. on regular ones 1280x1024 is generally good. but that also depends on what size ur screen is also
Jul 30, 2009 | Computers & Internet
Need to change setting from 800x600 to 1440x900 on a hp w1907 monitor.
If your using vista right click on the desktop and click personalization--->click on display settings -----> there is a bar for resolution drag it over to 1400x900.
IF your computer cannot display that particular size then your video card probably cannot handle that resolution. Either that or try to download a new driver for your video card to see if the new drivers will support it.
Mar 29, 2009 | HP w1907 LCD Monitor
19" Sansung monitor
you need to set the resolution to 1400x900, if this is not an option in the Display settings you should download the apropriate driver for you graphics card.  once you have ascertained  what make (nvidia or ATi), and model, go to one of the following for the latest drivers.
  • nvidia; http://www.nvidia.com/Download/index.aspx?lang=en-us
  • ATi; http://support.amd.com/us/gpudownload/Pages/index.aspx
After installation and reboot, you can then select 1400x900 screen size i the display settings.
Jan 28, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Toshiba Satellite P105-S6104 Notebook Logo
111 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
