Question about HP Scanjet 4300c Flatbed Scanner
I had a problem with my computer and had to uninstall the 4300c scanner and now I want to reinstall but the computer does not recognize it. I get a message that says it can not find specific path. can you help me with this
4 Suggested Answers
Santy
  • 14 Answers
SOURCE: HP Scanjet 4400c not recognized by Windows XP Home Edition
Try downloading the drivers from the HP website at: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=61902&lang=en
Posted on May 01, 2007
SOURCE: hp scanjet 3400c installation problem
No Way...
Problem with this scanner is: Microsoft has the wrong driver and HP delivers an uncertified driver that never gets itself correctly installed under XP. Scanner is likely to work just for one session. Do as I did. I am talking Dutch here.
Remove all software first and afterwards also folders like ProgramFiles\Hewlet Packard and other places were files were stored in. Maybe in Control Centre - System - Hardware Devices you may have Optical Devices - HP 3400C, Remove it also with right clicking and doing Undo Installation of the Driver and next unplug the scanner from the computer. Restart. Install the driver for migrating from early Windows version to XP. [url]ftp://ftp.hp.com/pub/scanners/software/sj652en.exe[/url] and, when done, restart with connecting the scanner when the computer is down. It now seems to be recognized and installed (like you must have seen before). Do not use the scanner on this stage. Now install the update [url]http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?lc=en&lang=en&cc=us&os=228&product=61835&dlc=en&softwareitem=sj651mu[/url] Restart again. Go back to System - Hardware Devices where you now certainly find the scanner under Optical Devices. Click right on it and choose Properties and Install the Driver Again or something alike in English. On the question Must Windows Search For It? Pick 'Not This Time." Next with "Install From a Certain Location." Then choose "Do not Search, I Want to Install the Driver Myself." Now choose the third and last driver from the list. So one of HP, not from Microsoft. You are only asked the question This Driver is Not Digitally Signed, Still Use It? and click Yes or OK. Your problem is finally solved and the program PrecisionScan will also work. Do remove the program update.exe from the folder or when watching system internals - just do not agree for the update possibility changes.
Posted on Apr 11, 2008
  • 5416 Answers
SOURCE: I have installed HP PHoto
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Posted on Aug 12, 2011
Install scanjet 4300c scaner in windows 7
1. If your scanner is connected to your computer (USB) uninstall it using the device manager, be sure to check the box that says "delete the driver." And, unplug the USB when it is uninstalled. When I did this had never installed the software previously in my Win 7 operating system.
2. Download the sj657 installer packaged from HP. http://h10025.www1.hp.com/ewfrf/wc/generic...=reg_R1002_USEN
Extract it to a folder. If you double click on the downloaded file it will try to open the setup file automatically and you will get a message saying the software only works on Windows 98, etc. Just cancel and go to the folder (Default location is C:sj657) and continue with the next step.
3. Select the "setup" app and right click on it to get properties, change the compatibility to XP (I did service pack 2). Then run the it and click "OK" on any warnings from Windows 7.
4. Go to the Hewlett-Packard folder now in your Program Files directory, there will be a "HP Precisionscan" folder. It will be the only one unless you have other HP products. Open the Precisionscan LTX folder and change all apps to XP compatibility. I also checked the administrator check box on each app (there are several) just in case.
5. Restart your computer.
6. Plug in your scanner via USB and let it in install. Windows 7 should give you a notice that your 4300C was installed successfully.
The scanner will now work using the LTX software installed on your computer. The buttons on the front do not appear to work, nor can you do anything with it by going to "scanners and cameras" in your control panel. BUT otherwise, it seems to work great and all the functionality is there in the LTX software.
Jul 02, 2012 | Dell Inspiron E1505 Notebook
Need to download rhombus rh1200 scanner driver
need driver for RHOMBUS RH-1200 US 600DPI USB SCANNER
May 21, 2011 | Computers & Internet
My scanner requres to establish connection with action manager 32
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot hope this helps
I need to install my visioneer scanner.
May 19, 2011 | Computers & Internet
HP Scanjet 4300c wont down load the driver for Vista OS
The following instructions were posted by Harlandas on the HP support forum:
Here are the directions:
2. Download the sj657 installer packaged from HP. http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=sj657en&jumpid=reg_R1002_USEN
Direct link:
http://h30434.www3.hp.com/t5/Scanning-faxing-and-copying/HP-Scanjet-4300C-compatibility-with-Windows-7/td-p/152092
Mar 03, 2011 | Computers & Internet
Repeated message "windows cannot load OmnisuperCam" Followed instructions and reinstalled carefully twice. Photo Impression 6 loads and is active. OVT does not appear in control panel 'scanner and camers'
Hi.
This often happens because Image Copier installation must be done in exact order as described in the instruction manual. To fix the problem you need to uninstall and reinstall everything back in right order.Also remember to restart the system when required.
  1. Unplug the image copier
  2. Uninstall the driver (remove from installed scanners and remove driver files).
  3. Uninstall PhotoImpression6
  4. Restart your computer.
  5. Install the driver,.
  6. Restart computer
  7. Reinstall PhotoImpression6 software.
During installation ensure that you authorize the system changes when asked. If possible disable any security software.
If that does not fix the problem, then the registry must be cleaned of any entry related to the scanner software. This is rather difficult to be done manual. You can try doing a system restore to a recent date before the problem started after uninstalling everything, and then uninstalling again if needed (application and scanner are there after SR), and finally reinstalling everything in order. If that does not work you can try a registry cleaner or reinstall the system.
Here a copy of the manual.
Jun 22, 2010 | Computers & Internet
Scanjet 4300C
Hope this helps, but there's no specific model number, but here's a description:
Round barrel connecter with a positive center. Voltage regulator, power supply, powersupply, inverter, adaptor, adapter, transformer INPUT: AC 100V and OUTPUT: +12VDC/1.25A (12 Volt 1250mA)
And, a photo:
Aug 25, 2009 | Office Equipment & Supplies
Hp scanjet 3400c installation problem
Did you check to see if there are updated drivers on the HP website for the device?
Jan 07, 2008 | HP Scanjet 3400c Flatbed Scanner
No picture on scan
Reinstall your Operating System of the Device .
May 29, 2007 | HP Scanjet 4300cse Flatbed Scanner
HP Scanjet 4300c Flatbed Scanner Logo
37 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
