Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
Adding harddrive tried to add a 250 g INTERAL HARD DRIVE AND THE SYSTEM WON'T BOOT UP
  • 80 Answers
Hi my name is wesley. you need to make sure the hard disk you put in is set to slave otherwise it clashes with your other hard disk and will not boot. you will see a jumper on the hard disk you can set to slave instructions is on the hard disk you just have to change witch two pins the jumper is on.
Posted on Jul 21, 2008
My hp cap light and number keeps flashing all the time
The Hard drive lost its Operating System and will no longer boot. If it sounds like it is spinning, try a reinstall the OS. If not Replace the drive.
Mar 06, 2014 | HP Pavilion Entertainment tx2500 Tablet...
Ctl lt1 netbook has welded in 4g hard drive. Can a dual booting be added so as to access a usb flash drive or sd card can be used to house an additional operating system that has enough room to add...
Certain OSs can be installed onto thumb drives, however installing additional software will likely not work. Most laptop harddrives can be replaced, though it is more difficult than a desktop. If you are uncomfortable or unknowledgeable with computer equipment, I suggest visiting a professional to replace the hard drive.
This website gives information on how to boot Windows XP from a USB drive.
http://www.techrepublic.com/article/solutionbase-boot-windows-xp-from-a-usb-flash-drive/5928902
to boot from a drive other than the harddrive, while your computer is turning on, early, before the windows logo appears, there should be an option to press one of the F keys to enter a boot menu. Pay attention to the screen, as it will only appear for a few moments before the windows on the hard drive loads automatically.
Mar 04, 2011 | CTL IL1 Notebook
I have samsung (Model hd501hi) hard disk but it
Hi. Sounds like a problem with the harddrive boot block. Try the torubleshooting steps i provided to you below. If same issue appears after thes troubleshooting then theres a need to replace your Harddrive.
* If you have a floppy try to boot with bootdisk http://www.bootdisk.com/
if you have a bootable windows CD - try booting that then go to the repair console.
have a good one!
Jul 29, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Jan 28, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Hard drives!
your harddrive is standard 30 gb on ide connection and u can ad a new hard drive on your notebook up to 250 gb ide but u will have to format the system brandnew
Jan 01, 2009 | Toshiba Satellite A15-S127 Notebook
Dual boot/hard drive seetings
Install first the media center on the primary harddrive with master jumpered.. when everything is working fine... then proceed to
the next harddrive. Set its jumper to slave not cable select and install xp pro, it ask you for an option to have dual boot then select the location of windows to be installed...
Hoping this helps... Fixya!!!
Feb 02, 2008 | Maxtor Hard Drive
Simpletech 160 Portable doesn't show up
go into the control panel and click add/remove hardware... and manually add the device and then use the auto update to download the drivers
Jan 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
141 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
