I have a LG washing machine Model # WM2688H*M it has a slight leak that I traced to a small black hose. The hose is in the back of the machine that goes from the bottom of the drum to the top somewhere that I cannot see. How do I remove the top cover? What does this hose do? The hose has 2 foam rings I guess they are for protection and vibration one of the foam rings is wet. Thank You. Dan
  • 1,543 Answers
It's not likely the hose is leaking, but rather water is leaking from somewhere else and is running down the outside of that hose. Remove the washer top by taking out the two phillips head screws from the bottom of the plastic clips on the back side of the washer's top. Now, stand in front of the machine and use the palms of you hands to sharply push the top cover back about 2 inches, then lift the cover off. Look for the water leak. The most likely suspect is a water inlet valve.
Posted on Jan 01, 2011
Lg tromm washer leaks from detergent drawer
my washer also was leaking from the dispenser and I had a cap from one of the detergent bottles stuck in the inlet hose. Don't know how it got in there but glad I found it so if your washer leaks from the soap tray it could be a cap from your detergent bottle stuck in there.
Nov 04, 2012 | LG WM2688H Front Load Washer
We have an LG Tromm Steamwasher WM2487HWM . 4.0 cu ft front loader....I see a lot of complaints about mildew and smell...we have the same problem....is it safe to take teh rubber seal off the washer to...
Replace the boot with new. While you have top and front off to replace boot, hose the drum down with a hose on stream. Remove filter clean out as you hose it down. Btw, there is no cleaning off the boot if it has mildew/mold on it.. it's slightly porous and no eliminating it
Aug 05, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washing machine LG WD1238C keeps showing error message OE hose is not blocked or filter blocked does not finish any cycle or work correctly
This sounds like a blockage in the small hose connected to the waste pump. Take the lid off and find the waste pump down near the bottom of the machine below the drum, then remove any one of the hoses connected to the waste pump and check inside the pump to make sure the fan can spin using your fingures, maybe a small kids sock or similar jammed in there, if nothing in the pump check both pipes on the waste pump
Dec 27, 2010 | LG WM-2277HW Front Load Washer
Water leaking on floor at right front corner of
check the door rubber for any tears,this is also called a boot glove.
Jul 14, 2009 | LG WM2688H Front Load Washer
Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
May 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM2688HM front loader is leaking water around the door seal
this may be coming from the soap dispenser and running down round the door way and to the bottom- investigate that first. otherwise the seal may be worn/ damaged and needs replacing.
Mar 16, 2009 | LG WM2688H Front Load Washer
Le code and will not drain or spin
I read a post on another site, here is the link for the owners manual, see page 18 for the LE error code
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
I simply unplugged my machine for 30 seconds, plugged it back in and it worked like a champ.
Oct 13, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
